Pic of their 71-74 Roadrunner/GTX? *updated*
#1487554
08/20/13 06:45 PM
08/20/13 06:45 PM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
I need to see how the radiator fits on the radiator support. The one that is installed on this 440 Airgrabber car has the radiator sitting about 1" away from the support. I think thats going to impact the distance I have mapped out for the fan/clutch assembly. If this is going to be a nightmare, might end up just replacing the radiator altogether and getting the correct fan shroud for the new one...
The one in there now is a 6-bolt radiator...and I can't find a shroud for it...supposedly out of an 80s Dodge Truck.
Just a vertical shot above the radiator support. I wanna see how it truly fits.
Many thanks
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Can someone take a pic of their 71-74 Roadrunner/GTX?
[Re: Pyper70]
#1487555
08/20/13 08:14 PM
08/20/13 08:14 PM
Posts: 565 IA
landon1
IA
I switched to an aluminum "race" radiator, so I can't take a picture, but the brackets are L-shaped and run the length of the radiator, holding it basically right next to the radiator support. It is a pretty tight fit in there
'71 Satellite Sebring 440
[Re: Pyper70]
#1487560
08/23/13 01:17 PM
08/23/13 01:17 PM
Pyper70
Athens, Greece
Here is the radiator as it sits on the support..
[Re: Pyper70]
#1487563
08/23/13 06:51 PM
08/23/13 06:51 PM
Posts: 3,335 home of the Buckeyes
Butterscotch71
Lost Title
Lost Title
both are 71 road runners
22"
addict:to devote or surrender (oneself) to something habitually or obsessively ....hmmmm
[Re: 471Magnum]
#1487567
08/24/13 09:03 PM
08/24/13 09:03 PM
Pyper70
Athens, Greece
Just for reference...how far is the end of the clutch supposed to be from the surface of the radiator? FSM doesn't say distance. I mocked it up today and it looks to be about 1" of air.
[Re: Pyper70]
#1487568
08/24/13 11:07 PM
08/24/13 11:07 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Not sure what the spec is, but typically I see 3/4"-1+"
Much closer than 3/4", you risk something bad happening in the event of a failed engine mount. Much more and the thermostat in the clutch will react slower.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
