203 part time kit #1487534
08/20/13 06:23 PM
08/20/13 06:23 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
any of ou guy's running the mile marker part time kit in your 203's?? i have a 203 in my 77 powerwagon an was thinkin of swapping in a np241 i have but hve heard the input shaft is to short?? the truck is goin to me my daily driver/mud toy, i would like to have part time 4wd back lol.. i will also be swapping to d60's... is the 203 a stroner case??
drive fast, drive hard, DRIVE MOPAR
Re: 203 part time kit [Re: lifted85] #1487535
08/20/13 06:26 PM
08/20/13 06:26 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If you really want part time, get a 205..
I am truckless..
Re: 203 part time kit [Re: 340SHORTY] #1487536
08/20/13 07:07 PM
08/20/13 07:07 PM
libby mt
lifted85 Offline OP
lifted85  Offline OP
libby mt
i got 1 but needs a center bearing. dont want to fork out the cash now to rebuild it at the moment.. the 203 seems to be workin but am just wondering about the part time kits
Re: 203 part time kit [Re: lifted85] #1487537
08/20/13 07:17 PM
08/20/13 07:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They will work but junk in my opinion, I would use the np241.
Re: 203 part time kit [Re: NITROUSN] #1487538
08/20/13 10:22 PM
08/20/13 10:22 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
I had one in my 78.It was in another Ram that I bought for parts.I plowed and put at least 40K on the setup.Only problem I had was I snapped some bolts in the frt hub once.I plowed and drove it every day fro at least 5 years.Rocky
Chrysler Firepower
Re: 203 part time kit [Re: NITROUSN] #1487539
08/20/13 11:48 PM
08/20/13 11:48 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
The 241 doesn't seem to get the respect it deserves. It actually has a better gear ratio than the 205 and will handle nearly the same torque, and horsepower.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 203 part time kit [Re: hp383] #1487540
08/21/13 12:17 AM
08/21/13 12:17 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
If you're strapped for cash, put the part time kit in the 203 and don't look back. Eventually it'll have trouble staying in 4wd and will pop out when you least want it to but it'll work well for awhile provided the t-case is in decent shape to begin with.
Re: 203 part time kit [Re: therocks] #1487541
08/21/13 01:23 AM
08/21/13 01:23 AM
scratchnfotraction Offline
I used to run a part time kit in my 79 RC with a 203 full time xfer, worked fine for me for yrs.
i also installed the chainsaver from milemarker, that would let you adjust the slop out of the xfer chain when it got worn and wanted to slip. that saved my old worn 203 for a long time.
I used the milemarker M&M locking hubs with brass dails up front that were trouble free.
Re: 203 part time kit [Re: lifted85] #1487542
08/22/13 04:08 PM
08/22/13 04:08 PM
VA
sls001 Offline
sls001  Offline
VA
The 203 has a different mounting bolt pattern than the 241 (or the 208 and 205's) so you would need to either swap transmissions or at least the tail-shaft with a newer model trans that has the correct bolt pattern.
Re: 203 part time kit [Re: sls001] #1487543
08/22/13 05:59 PM
08/22/13 05:59 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
No they don't. They bolt to any dodge 4wd trans. Pulled a 70s 4wd 727 That bolts to a 203 off of a 241. Bolts rite up
Re: 203 part time kit [Re: 76dodgeboy] #1487544
08/23/13 02:14 PM
08/23/13 02:14 PM
VA
sls001 Offline
sls001  Offline
VA
Yes, they do
The 203's use an unique trans adapter, the 241 will require an adapter from a 205, 208, or 241 equipped auto Dodge.
The 727 output for the 203 will be too short for the 241, you'll have to get the right trans output for a 208 or 241 and install it in the 727.
About 1/2 down in this post you can see the difference in the 203 and 208/241/205 bolt pattern and shaft length difference:
http://ramchargercentral.com/technical-discussion/drill-205-6-bolt-pattern-to-203-adapter/
http://www.pirate4x4.com/forum/dodge/1013227-swap-241-203-205-doubler.html
http://ramchargercentral.com/technical-discussion/np-241-to-np-203-swap/
http://ramchargercentral.com/technical-discussion/transfercase-swap!/
Here is an image to show the difference 203 on the left 205 on the right:
Re: 203 part time kit [Re: sls001] #1487545
08/23/13 04:02 PM
08/23/13 04:02 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
If that's the case how is hp383 running the Stock 93 T-case with a 440/727.
Re: 203 part time kit [Re: 76dodgeboy] #1487546
08/23/13 04:07 PM
08/23/13 04:07 PM
VA
sls001 Offline
sls001  Offline
VA
Simple - tailshaft w/tail housing swap
Re: 203 part time kit [Re: sls001] #1487547
08/23/13 04:29 PM
08/23/13 04:29 PM
is that a dodge 205 or chebby 205?
Re: 203 part time kit [Re: scratchnfotraction] #1487548
08/23/13 06:15 PM
08/23/13 06:15 PM
VA
sls001 Offline
sls001  Offline
VA
Dodge 23-spline
Re: 203 part time kit [Re: sls001] #1487549
08/23/13 07:26 PM
08/23/13 07:26 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Nope. Stock 70s bigblock 4wd trans and Stock 93 Transfercase. Read slowly.
They are BOLTED to EACH other.
Re: 203 part time kit [Re: 76dodgeboy] #1487550
08/23/13 08:20 PM
08/23/13 08:20 PM
VA
sls001 Offline
sls001  Offline
VA
Where is his build thread?
Re: 203 part time kit [Re: sls001] #1487551
08/23/13 09:41 PM
08/23/13 09:41 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Fastback66's garage. And his own garage. Im in thwarting process if swapping in a 518 for him. there's half inch to an inch diff in output shaft length. Otherwise it bolts up.
