69 Coronet Interior Questions #1487458
08/20/13 03:52 PM
08/20/13 03:52 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Could a 69 Coronet 440 come with a cloth & vinyl bench seats? I assume that is has the same door panels as a Super Bee.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: 69 Coronet Interior Questions [Re: Erik] #1487459
08/20/13 07:06 PM
08/20/13 07:06 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Yes and no...
The Cloth and Vinyl interior was available on the WH41 (Coronet 440) four door sedan (H1*). Cloth and Vinyl was N/A in two door HT's like the Coronet 440, Super Bee, Coronet 500 and R/Ts.
The Super Bee interior was either H2* (bench vinyl) or M6* (bucket vinyl). The door panels were different between the two interiors.
So yes, Coronet 440 four doors could come with cloth and vinyl seats but no, the door panels are not the same as a Super Bee.
If you want door panels for a SB with an H2 interior, look for them in Coronet 440 two door coupes and hardtops.
If you want door panels for a SB with M6 interior, they are the same as Coronet 500 and R/T two door HTs and convertibles.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: 69 Coronet Interior Questions [Re: 69CoronetRT] #1487460
08/20/13 08:41 PM
08/20/13 08:41 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks. Today I picked up a 69 Coronet 440 2 dr hardtop and it has cloth/vinyl bench seat in it. I would assume they were swapped in from another vehicle based on your answer. It needs new door panels, so I will get panels for a bee. It's just a tool around driver so I don't need it to be 100% correct.
Thanks!
Re: 69 Coronet Interior Questions [Re: Erik] #1487461
08/20/13 09:03 PM
08/20/13 09:03 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Is the tag still there and if yes, what is the interior code? Are both the front and back seats c/v or just the front?
Seeking:
Re: 69 Coronet Interior Questions [Re: 69CoronetRT] #1487462
08/20/13 09:12 PM
08/20/13 09:12 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
No tag. Front and back are c/v. It also has '68 door panels.
Re: 69 Coronet Interior Questions [Re: Erik] #1487463
08/21/13 08:56 AM
08/21/13 08:56 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
4 door seats are different than 2 door seats so , fronts don't fold forward and the rear bottoms have rounded corners, because they are exposed when the rear door is open, for easy in and out .
Re: 69 Coronet Interior Questions [Re: JohnRR] #1487464
08/21/13 11:18 AM
08/21/13 11:18 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Thanks, John. They definitely fold down!
Re: 69 Coronet Interior Questions [Re: Erik] #1487465
08/21/13 12:10 PM
08/21/13 12:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Since you say it has 68 door panels they could be from anything. Got a picture ?
Re: 69 Coronet Interior Questions [Re: JohnRR] #1487466
08/21/13 12:26 PM
08/21/13 12:26 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I'll post some later.
Re: 69 Coronet Interior Questions [Re: JohnRR] #1487467
08/21/13 04:03 PM
08/21/13 04:03 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I stand corrected - after a little more research, it looks like it has '70 Charger door panels. In any case, they need to be replaced.
Re: 69 Coronet Interior Questions [Re: Erik] #1487468
08/21/13 09:40 PM
08/21/13 09:40 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Interior Pics:
Re: 69 Coronet Interior Questions [Re: Erik] #1487469
08/21/13 11:42 PM
08/21/13 11:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That doesn't look like anything I have ever seen from Chrysler.
Re: 69 Coronet Interior Questions [Re: Erik] #1487470
08/21/13 11:47 PM
08/21/13 11:47 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Those inserts were redone at some point, looks like a velour, not factory, which explains why there is cloth on 2 dr seats. In other words they are incorrect but look to be in nice condition.
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: 69 Coronet Interior Questions [Re: mopargem] #1487471
08/22/13 07:28 AM
08/22/13 07:28 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I am not too worried about "correct" on a 440, so I will not recover the seats. But the door panels have got to go! They look pretty bad.
Re: 69 Coronet Interior Questions [Re: Erik] #1487472
08/22/13 11:26 AM
08/22/13 11:26 AM
KY USA
mopargem Offline
mopargem  Offline
KY USA
Try to avoid PUI panels, they are too puffy and not all the mount pin holes etc are punched on the backer. Legendary way better. Also the bucket seat panels require additional chrome/woodgrain mouldings
Re: 69 Coronet Interior Questions [Re: mopargem] #1487473
08/22/13 11:45 AM
08/22/13 11:45 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
The Legendary panels are nice. Used them several times.
Re: 69 Coronet Interior Questions [Re: mopargem] #1487474
08/22/13 11:53 AM
08/22/13 11:53 AM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I have bench seats.
