Warped Rotor Mabe not - see this #1487443
08/20/13 03:47 PM
08/20/13 03:47 PM
Oklahoma City OK
Cudajon Offline OP
Cudajon  Offline OP
Oklahoma City OK
Just put drilled and slotted rotors and new ceramic brake pads on my Ram SRT 10. After a high speed bring down last month I thought I had warped a rotor so I upgraded. The "warped rotor" was really terrible driving. When I took the old rotors and pads Off I discovered one of my brake pads had split. This was causing the warped rotor sensation. These pads are the z16 ceramic type pads. I had put them on last year, and yes I went through the break end procedure as recommended. They were fine for almost year, look how much material is left on them:
Re: Warped Rotor Mabe not - see this [Re: Cudajon] #1487444
08/20/13 04:48 PM
08/20/13 04:48 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It looks like the pad may not have been manufactured properly. If one strong heat cycle flaked the pad material it makes me think it was not bonded properly.
There are a few probelms with the Powerstop pads. Either get them exchanged or pick up a better quality pad from a company like EBC.
- Stu Harmon
Re: Warped Rotor Mabe not - see this [Re: Cudajon] #1487445
08/20/13 04:53 PM
08/20/13 04:53 PM
dogdays Offline
dogdays  Offline
Feets speaks the truth, that should not have happened, looks like a warranty issue to me.
Don't know about the application but I have never had a bad Performance Friction Carbon Metallic pad.
R.
Re: Warped Rotor Mabe not - see this [Re: dogdays] #1487446
08/20/13 05:05 PM
08/20/13 05:05 PM
MA
steve70 Offline
steve70  Offline
MA
Although probably not the issue I've seen a lot of people install slotted rotors on the wrong side. Here's the right method http://zeckhausen.com/how_to_properly_install_rotors.htm
1970 Challenger T/A 4 speed
Re: Warped Rotor Mabe not - see this [Re: steve70] #1487447
08/20/13 07:24 PM
08/20/13 07:24 PM
Oklahoma City OK
Cudajon Offline OP
Cudajon  Offline OP
Oklahoma City OK
Slotted rotors are new, this happened with the stock rotors. If the slotted ones are marked correctly I've got them where they should be.
Re: Warped Rotor Mabe not - see this [Re: Cudajon] #1487448
08/20/13 08:01 PM
08/20/13 08:01 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Im glad you guys dont work on cars for a living.Just figure a manufacturer makes millions of parts.There are bound to be bad ones.Ive had NAPAs best brakes have the friction material fall off the plate.It happens and it seemed like Mopar pads were the worst.Just like buying a part and the guy says "It cant be bad because its new".Over the last 30 years Ive seen it all.Ever tune a car and wonder why it wont start now with all new parts.Then pull the cap back off and discover either the carbon button or the steel strip on the rotor was installed.New brake druns from Wagner that made the car feel like it was coming apart because they were warped so bad.The list goes on and on.Rocky
Chrysler Firepower
Re: Warped Rotor Mabe not - see this [Re: therocks] #1487449
08/20/13 11:47 PM
08/20/13 11:47 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Had a mopar OE rear brake shoe loose it's lining on the road...That was a fun ride...Spun around and lodged between the other side's shoe...Locked up the one side on the highway for the slide into homeplate...
Re: Warped Rotor Mabe not - see this [Re: screamindriver] #1487450
08/21/13 03:38 AM
08/21/13 03:38 AM
dogdays Offline
dogdays  Offline
Rocky, what's your point? Sure there are bad parts out of the box, but thats why there are warranties! If the pads were worn out that'd be different.
My favorite was a NAPA windshield wiper motor dead out of the box. Took me days to figure that one.
R.
Re: Warped Rotor Mabe not - see this [Re: dogdays] #1487451
08/21/13 08:02 AM
08/21/13 08:02 AM
Niles , Ohio
Niles , Ohio
Dogdays my point was take them back.Some guys act like a part thats bad is a major crime.Yeah its a pain but after 30 years of doing it every day you find out it happens.Just like buying a new car.You can get one that goes 500K with no problems and the guy next door buys the same and has it in the shop every week.Its man made so stuff that is bad happens.Only time it really POed me was when it took a lot of time and then you find out the part is bad.Had a water pump I installed {insert type}.Bolted it all in and was finishing up the job.Guess what it wouldnt turn as it wasnt pressed on enough.Cussed a bit and tore it back off.If the pads have a warranty bring them back.Rocky
Chrysler Firepower
Re: Warped Rotor Mabe not - see this [Re: therocks] #1487452
08/21/13 10:05 AM
08/21/13 10:05 AM
ill
dennismopar73 Offline
ill
Ok, first off you can spot a cheap pad anywhere, looks like you have a cheap pad,
Sorry but is what it is . there ae only a
Only a few makers of the pads, that make all the brakes, some produce their own back plates some reuse old plates,
heat was the killer here, pads glazed tons of dust,
other killers of brakes is bad driving habits, mis use and abuse of brakes , and improper install of brake pads from the start!
Bad bolt pins, not cleaning or replacement of the sliders and anti chatter clips,etc
just because you put a drilled and slotted rotor doesn't mean that it was a great thing on a 5000,-6000 # vehicule and try stopping on a dime from over 100 mph!!
If you wanted a sports car , buy that it will !
Re: Warped Rotor Mabe not - see this [Re: dennismopar73] #1487453
08/21/13 03:50 PM
08/21/13 03:50 PM
Niles , Ohio
Niles , Ohio
When we did ambulances at the shop we used the Sever duty pads.Our cost was 50 bucks for most.When you are trying to stop one of them with all the equipment and people the price was cheap.Plus they usually lasted longer than a regular pad.Rocky
Chrysler Firepower
Re: Warped Rotor Mabe not - see this [Re: therocks] #1487454
08/21/13 06:56 PM
08/21/13 06:56 PM
Amherst,NY
challengermike Offline
Amherst,NY
Wouldn't a slotted rotor use a pad that's tapered on the end so it doesn't grab the slot ? The set I put on mine where. I see those are not and wonder if that's why it happened.
Re: Warped Rotor Mabe not - see this [Re: challengermike] #1487455
08/21/13 07:06 PM
08/21/13 07:06 PM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
And maybe put a bit of anti-seize on the slides (you didn't use any) so the pad will move properly.
Re: Warped Rotor Mabe not - see this [Re: challengermike] #1487456
08/21/13 07:41 PM
08/21/13 07:41 PM
ill
ill
the 'tapered' edges you say is there for 2 reasons, 1 is to keep the pad clean the other is to get a slite amount of air to cool the pad between cycles , the slot in the middle is to let the gasses that get generated from the braking sequence to escape, as well as dust and debri
, the pads you see in the pic are so glassed it holds a picture!
the edge is squared showing it is a cheaper made pad, the pads also show no signs of any brake grease applied to slides , or other places.
Most people will just throw pads on never do the other work needed, nor wash rotors off, as well as clean replace slides worn bolts, because , well looked good to me , and done it before never have an issue!!
Looking at the pad heat was the issue, and was there for some time so a prolong braking effert was used.
Re: Warped Rotor Mabe not - see this [Re: dennismopar73] #1487457
08/21/13 09:30 PM
08/21/13 09:30 PM
IN
ahy Offline
ahy  Offline
IN
Agree you should return them. I'll add that "bedding in" the pads before severe use is good practice. Bear brakes publishes a sequence. Basically it amounts to progressively more severe brake cycles to bring them up to temp gradually followed by cool down. That may help the new pads survive the hard braking. Also at least de-glaze the rotors before re-assembly. A light touch with a DA and some 80 grit works.
