E-body instrument lights - Revisited #1487426
08/20/13 03:40 PM
08/20/13 03:40 PM
Moved to N.E. Tennessee
GomangoCuda Offline OP
All of them have stopped working including aftermarket guage lights that were also on the same circuit. Is this likely the switch and were can I get one?
Re: E-body instrument lights [Re: GomangoCuda] #1487427
08/20/13 03:54 PM
08/20/13 03:54 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check the fuse...
Just my $0.02...
Re: E-body instrument lights [Re: Sinitro] #1487428
08/20/13 11:53 PM
08/20/13 11:53 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Check the fuse...
Just my $0.02...
It's the one marked "instruments" hope that makes it an easy fix..If it's not the fuse then you're going in deeper...
Re: E-body instrument lights [Re: screamindriver] #1487429
08/21/13 12:14 AM
08/21/13 12:14 AM
IN
ahy Offline
ahy  Offline
IN
The OE headlight switch has a rheostat to control brightness. If the windings get dirty or fail, all lights are out or the fuse blows. One fix is to solder in a jumper to bypass the rheostat. Lights will always be full bright but they will work.
Re: E-body instrument lights [Re: ahy] #1487430
08/21/13 10:52 AM
08/21/13 10:52 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Have your dash switch restored. Contact JS Restorations.
Re: E-body instrument lights [Re: burdar] #1487431
08/21/13 11:09 AM
08/21/13 11:09 AM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
bypass the panel dimmer switch
Re: E-body instrument lights [Re: ahy] #1487432
08/21/13 11:11 AM
08/21/13 11:11 AM
BDW Offline
BDW  Offline
This is what I did and it works great. Never had a need to dim them.
Re: E-body instrument lights [Re: ahy] #1487433
08/21/13 12:25 PM
08/21/13 12:25 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
No need to solder..
Make a short jumper wire with (2) 0.25" tab connectors insert into the 3 prong connector originally on the dimmer switch. Next run a short wire back to the switch for the dome lite ground. All plug-in, no cutting or soldering..
Just my $0.02...
Re: E-body instrument lights [Re: Sinitro] #1487434
08/30/13 09:43 PM
08/30/13 09:43 PM
No need to solder..
OK, which 2 get jumped to each other and which one goes back to the switch? one has 2 yellow wires, center has tan wire, last is black and black with a stripe.
I'd rather have no lights than sparks and smoke.
Fuse is good.
35 years ago I could almost do this in my sleep. Now I get a sore neck from trying to see under the dash with bifocals and the wiring diagram is giving me a headache.
Re: E-body instrument lights [Re: GomangoCuda] #1487435
09/01/13 03:19 PM
09/01/13 03:19 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
No need to solder..
Fuse is good.
Yellow is the ground, goes back to the switch. Tan is the power coming in, that gets jumped to the blk/blk with yellow tracer.
Just did mine , wow what a diff, din't think my switch was that bad just used to cut out once in a while.
Gary.
Re: E-body instrument lights [Re: burdar] #1487436
09/01/13 04:04 PM
09/01/13 04:04 PM
Pittsburgh, PA
Slotts Offline
Slotts  Offline
Pittsburgh, PA
Thank you, Darren.
Yes, the 2947713 dash dimmer switch is my most requested switch needing restored on an E body.
Re: E-body instrument lights [Re: Mr340] #1487437
09/01/13 11:42 PM
09/01/13 11:42 PM
Gary.
Thanks, I will probably try this tomorrow and sent a PM to JS Restorations.
Re: E-body instrument lights [Re: GomangoCuda] #1487438
09/03/13 09:35 PM
09/03/13 09:35 PM
Bucks County, PA
500Stroker Offline
500Stroker  Offline
Bucks County, PA
Bypassing the dimmer switch is the way to go.
Re: E-body instrument lights [Re: 500Stroker] #1487439
09/04/13 02:10 AM
09/04/13 02:10 AM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Sure looks a lot brighter than mine!! Ha ha!!
Re: E-body instrument lights [Re: 500Stroker] #1487440
09/04/13 06:04 AM
09/04/13 06:04 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
The only issue with the bypass is you lose the ability to turn on the dome lite, if that matters to you. it doesn't to me
Re: E-body instrument lights [Re: Mr340] #1487441
09/04/13 07:03 AM
09/04/13 07:03 AM
BDW Offline
BDW  Offline
If you solder a jumper across the terminals (bypassing the variable resistor) the dome light still works.
Mine does
Re: E-body instrument lights [Re: BDW] #1487442
09/04/13 09:40 PM
09/04/13 09:40 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Mine does
Good Point
I used the No Soldering method, (plug in jumper wires).
