When MPG goes up...does HP always go up??
#1487185
08/20/13 01:30 AM
08/20/13 01:30 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Had a discussion with my bro in law about efficiency vs. HP gains yesterday. As with most conversations with him (he is a bowtie minion) things got heated. In any case, when a gain in MPG is observed does this ALWAYS mean that HP goes up also? I have my opinion, but need some good info to back me up. Any feedback, links to articles, etc is greatly appreciated!!!
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: When MPG goes up...does HP always go up??
[Re: Von]
#1487187
08/20/13 03:23 AM
08/20/13 03:23 AM
Posts: 43,202 Bend,OR USA
Cab_Burge
If a motor is rich and you lean it down it will probally make more HP at the same rate of fuel consumption (Brake Specicif Fuel Consumption optimum fuel consumption air fuel ratio at steady state accorduing to the Society of Automotive Engineers is 14.25 to 1 or .42 lbs per HP per hour How about them numbers, lay them on him ) as before with less throttle opening, hence better fuel milage. If the motor is lean and you enrichen the mixture to make it best AFR it will increase the HP and possibly the fuel mileage, maybe not Bottom line is the slower(RPM) you can make the motor run at a specific speed and not have to go to full throttle it will use less fuel per mile at the lower RPM Lots of things involved in making good fuel mileage, not just HP
[Re: Von]
#1487188
08/20/13 07:28 AM
08/20/13 07:28 AM
Posts: 4,314 Prospect, PA
BSB67
Prospect, PA
...when a gain in MPG is observed does this ALWAYS mean that HP goes up also?
No.
[Re: Von]
#1487189
08/20/13 08:38 AM
08/20/13 08:38 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Short simple answer: if a fuel economy gain comes from less friction inside the engine or a faster burn in the cylinder that requires less degrees of ignition timing then there is usually also a power increase too. Recently, with many engines getting Variable Valve Timing, this feature usually adds better fuel economy 1500 to 2500 rpm and increased HP 3500 to 6500+ rpm.
Long answer
MPG is for an entire vehicle travelling on a specific road.
Horsepower for an engine is usually used refering to a "peak" power measured by a set of rules such as SAE or Standard Dyno, but can also be "instantaneous power" under different comditions.
Transmission/differential gearing ties the engine to the vehicle and certainly affects both MPG and Torque at rear wheels.
If the pavement changes from rough new blacktop to smooth old concrete the MPG goes up, but peak hp is unchanged.
If air temp goes up, mpg goes up but instantaneous power available goes down, and so forth.
If a different gear is used on a specific section of road MPG may change but peak rated HP is not.
To get away from such difficulties, engineers create various styles of maps, comparing more than two things at once, such as:
Power versus RPM versus Throttle Opening versus Fuel Flow
Torque produced vs RPM vs Fuel flow
Perhaps the best such map is the one that compares
Brake Mean Effective Pressure ( gives both Torque and HP) versus Average Piston Speed ( depends on rpm and crank throw) versus Fuel Consumption expressed as mass of fuel used up during an hour of power produced, which is called in techno-speak as Brake Specific Fuel Consumption or shortened to initials BSFC
[Edit: See examples several posts down from this one]
While the above sounds complicated it is a "universal" map that can be used to compare engines of any size, stroke, cycles from tiny weed whacker engines to automotiveV8s all the way up to huge 100,000 HP ship engines
Any change that improves fuel economy in an area within such a universal map usually also improves torque and HP but only near that specific piston speed.
At higher or lower piston speeds a change might cause the BMEP to go up but the BSFC may not ... could go up, down or stay the same.
[Re: HotRodRailroader]
#1487191
08/20/13 12:14 PM
08/20/13 12:14 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Top Fuel dragsters dont get 100 MPG but they have 1500 HP
More like 5000 hp. Ron
[Re: BSB67]
#1487192
08/20/13 12:18 PM
08/20/13 12:18 PM
Von
NE Oklahoma
No.
Agreed...
[Re: Von]
#1487193
08/20/13 12:22 PM
08/20/13 12:22 PM
Von
NE Oklahoma
360view, thanks for the info!!!
Let me pose this question...if I gain 1mpg from changing spark plugs (which I did on my daily driver, the old plugs were not "old", I just swapped to a different design)did/do I have to be making more power?
Obviously efficiency went up, but did power HAVE to go up as well?
[Re: Von]
#1487195
08/20/13 02:45 PM
08/20/13 02:45 PM
Posts: 654 MN
astrobuf
MN
Depends upon how the mpg increase was obtained. If the vehicles resistance us reduced, mpg will go up and no more fkywheel hp is produced, but rear wheel hp will go up.
If the engine is leaned out, mpg will go up, but usually hp will go down.
Astrobuf
So, are you really a Rocket Scientist?
[Re: 360view]
#1487196
08/20/13 03:04 PM
08/20/13 03:04 PM
Von
NE Oklahoma
Any change that improves fuel economy in an area within such a universal map "usually" also improves torque and HP
The key word to me is "usually"....
360, Since you used the term "usually", what is/are some instances where efficieny is improved but HP does not go up? Is there an instance (not including the examples give, (such as quality of road surface, etc) where efficiency goes up and more power is NOT made?
[Re: astrobuf]
#1487197
08/20/13 03:06 PM
08/20/13 03:06 PM
Von
NE Oklahoma
Again, the key word is usually.
Where do most engines make max power?
But, this is getting OT of my original question.
[Re: 360view]
#1487199
08/21/13 11:24 AM
08/21/13 11:24 AM
Posts: 8,162 USA
360view
USA
attached JPEG picture is a graph of a typical 1960s automotive engine performance map with BMEP (brake mean effective pressure which is similar to torque per cubic inch of displacement) plotted against Piston Speed in Feet per minute (convert to RPM using stroke in feet instead of inches)
From Volume I of Charles Fayette Taylors classic book on engines "The Internal Combustion Engine in Theory and Practice" figure 12-16.
Modern engines have improved about 7% in fuel economy BSFC for each ten years, so the ovals of best fuel economy would be smaller numbers than the 0.500 pounds of mass per horsepower hour here, except that this is for "pure" 120,000 BTU per gallon gasoline and today it it blended with ethanol down to as little as 107,000 BTU per gallon in some winter blends.
The upper line for BMEP which tops out in this 1960s data at 120 psi, would now go up to the 138 psi to 160 psi range. Seems like I remember that both the 1995 cast iron Magnum 8L V10 and Magnum 5.9L V8 maximum torque values calculate out to about 138 psi.
[Re: 360view]
#1487200
08/21/13 11:35 AM
08/21/13 11:35 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
Reading this makes my head hurt! Very good info!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: 360view]
#1487201
08/21/13 11:37 AM
08/21/13 11:37 AM
Posts: 8,162 USA
360view
USA
Here is a more modern engine performance graph which is unfortunately metric, from page 559 of the Fourth Ed of the Bosch Automotive Handbook.
The ovals are now total thermal efficiency fractions. 0.34 would be 34% efficiency
Torque is in Newton Meters
Instead of RPM the nutty Bosch-co-vites use the odd number "Radians per Second". There are 6.28 Radians in each shaft rotation and 60 seconds in a minute, so the 400 R/sec figure on the bottom middle of the graph is the same as 3,821 RPM
Do you think that an "overdrive" transmission is one where the driveshaft turns faster than the engine RPM?
Well the Bosch-co-vite engineers define a 'overdrive' ratio as one where the combination of engine and transmission gears can or can not bring the vehicle up to its theoretical top speed, so if you think your 2.76 diff gear 727 acts in all practical terms like a 3.92 diff gear 518 trans then you are in their camp.
The lines on the graph running bottom left to upper right with numbers at their top like 0.71, 0.85, 1.0, 1.12 are 'overdrive' ratios.
[Re: Von]
#1487203
08/21/13 04:04 PM
08/21/13 04:04 PM
Posts: 8,162 USA
360view
USA
[.... what is/are some instances where efficieny is improved but HP does not go up?
The one special case where efficiency goes up, but peak torque and max HP goes down is the "Atkinson Cycle"
http://www.animatedengines.com/atkinson.html
http://en.wikipedia.org/wiki/Atkinson_cycle
I guess to be fair to the original Mr James Atkinson his original idea had a very different crankshaft mechanism that gave a bigger expansion ratio than compression ratio, so it is when modern manufacturers twiddle with conventional intake valve timing, either closing it extra early, or leaving it open extra late so that "reversion" happens on purpose, that there is a penalty on peak HP.
[Re: 360view]
#1487204
08/21/13 04:40 PM
08/21/13 04:40 PM
Posts: 8,162 USA
360view
USA
i guess another common factor when the fuel economy goes up but torque and max HP goes down is when the air to fuel ratio is leaned out. Somewhere between 18 and 28 air to fuel ratio missfiring begins to increase and fuel economy and torque both go down Very lean a/f burn engines are similar to Atkinson cycle engines in that their expansion ratio per lb of fuel is high. Also very lean mixtures 20 to 28 a/f can be more highly compressed without detonation than the "worst to ping" 14.7 to 17 a/f ratios can Half throttle Atkinson Cycle gasoline engines, Lean Burn gasoline engines, and quarter rack position loaded diesel engines, are all operating in somewhat similar conditions inside the cylinder come to think of it
