Lift-off hood rubber grommet #1487021
08/19/13 09:00 PM
08/19/13 09:00 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I am going to try to replace these rubber grommets that go on the pins and underneath the lift-off fiberglass hood. Does anyone recognize them or what else has anyone used?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Lift-off hood rubber grommet [Re: cdstl] #1487022
08/20/13 01:41 AM
08/20/13 01:41 AM
San Francisco Ca
SCATPK Offline
SCATPK  Offline
San Francisco Ca
If you are dealing with a 69.5 bee or roadrunner those are not factory pieces. Just a short piece of heater hose between the bottom of the pins and the hood. Those are probably something a previos owner used.
Re: Lift-off hood rubber grommet [Re: SCATPK] #1487023
08/20/13 09:00 AM
08/20/13 09:00 AM
STL
cdstl Offline OP
cdstl  Offline OP
STL
I think that they might have been a MP piece at one time. Just wondering if someone had seen them or knew where to find them. I will probably get some heater hose.
Re: Lift-off hood rubber grommet [Re: cdstl] #1487024
08/20/13 09:15 AM
08/20/13 09:15 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
The heater hoses are what set the hood height,
non-stock hood or pins?
Joe
