Re: 340 6 pack intake porting??? [Re: superwrench] #1486869
08/20/13 09:55 PM
08/20/13 09:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Im sure even with the stock 6 pack and carbs on top of a good 416" i will have no trouble seeing 11.50's and maybe quicker before they toss me out of the strip for no bar.
The 6 Pack will be an easy way to slow you down.
Never say that.....I just ran 10.80's last weekend.
Everyone says that I'd run 10.60's with a good single plane and 4 bbl....not that I don't believe them, but why change when I'm having a blast making mine run quicker and quicker.
Re: 340 6 pack intake porting??? [Re: TJP] #1486870
08/20/13 10:21 PM
08/20/13 10:21 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I know the bb intake is a good performer. Just not a lot of info or tips on the sb old eddy or the newer mopar.
Re: 340 6 pack intake porting??? [Re: RobX4406] #1486871
08/21/13 12:25 AM
08/21/13 12:25 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The big block intake is a different deal than the SB one...
Which part of this did you big block guys that suffer from reading comprehension issues miss?
Re: 340 6 pack intake porting??? [Re: ademon] #1486872
08/21/13 12:13 PM
08/21/13 12:13 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
I think the stock carbs out-flow the mechanicals. FWIW I'm pretty much under 11.50 (unless I blow the tires up) and haven't been asked to leave yet. They key is to put 12.0 @ 115 on your tech card. Usually the guy handing out slips isn't looking inside the car for a cage.
The 4782/4783 mechanicals have exactly the same venturi diameter, booster and throttle bore diameter as the original carbs so obviously they would flow the same. Just because they look similar to the old Ford 3x2 don't assume they are the same. They are in fact much larger and are a nice upgrade on the Ford as well.
there rated at 1355cfm, i know when compared to 4bbl rating i think they are in the 975 cfm range same as the stock vacuum carbs. The manifold ports are quite a bit smaller than the gasket so at the very least i will gasket match them to the heads.
As far as cfm goes there is much speculation about actual flow capability vs a large 4bbl. The old Mopar race manuals said that the outers flow 425 cfm and the center flows 295cfm. Not coincidently the outers have the same venturis and throttle bores as an 850 cfm double pumper and the center has the same as the primaries of a 590 cfm holley 4 barrel. So basically the six pack is an 850 cut in half with the front of a 590 put in the middle. 850+295=1145cfm.
I would have to agree with that. Probably neither one can take full advantage of the carbs cfm but the small block intake is certainly smaller than the bigblock.
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486873
08/21/13 01:16 PM
08/21/13 01:16 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We just did a 416 (340 sixpack) engine. We sent the sixpack intake out to extrude hone. Engine made 580HP/550TQ on the dyno w a mild hyd/rlr cam.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486874
08/21/13 08:55 PM
08/21/13 08:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You've missed some key aspects: 1) The boosters in the outboard carbs are different than an 850 (i.e. take up more space), 2) the throttle shafts are not slabbed like an 850 (again, taking up more cross sectional area in the throttle bore, and 3) the throttle plates are aluminum and considerably thicker than in an 850. There are notable differences between an 850 and the outboard carbs.
If the six pack carbs flow 1350 cfm @ 3.0" Hg, and the 850 @ 1.5" Hg, as stated by Holley, then the science and associated math is simple. The six pack will flow 955 cfm @ 1.5" Hg. The question in my mind is if Holley"s numbers are real.
Re: 340 6 pack intake porting??? [Re: ademon] #1486875
08/22/13 08:47 AM
08/22/13 08:47 AM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
I shift my AAR at 7000 and it has hit the rev limiter quite a few times set at 7500. My 340 six pack loves to rev. Best time 12.3 @ 109. It slows down if I shift it anywhere lower than 6600 rpms. It has also gone 11.90 with a small shot of nitrous through the 6 pack intake.
Nice! Is that the old Eddy intake or the Mopar? I thought I read somewhere that the intake hit a flat spot around 6,200 rpm but then made power again past that if pushed higher.
Stock intake and stock carbs. Carbs tuned by me (modified the plates in the secondaries, lighter springs, and appropriate power valve). And yes, I did port match the intake manifold runners to the head ports, but just to match up (smoothly transition) the size of the ports from the intake manifold to the heads. By the way, my AAR ran slower when I put on an M1 and a single 4 barrel.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 340 6 pack intake porting??? [Re: 11secaarcuda] #1486876
08/22/13 09:02 AM
08/22/13 09:02 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
My Intake has been "deburred" and otherwise is stock. It has taken me to mid 11s on junk tires without any problems. Bolt one on and have fun.
Re: 340 6 pack intake porting??? [Re: scatpacktom] #1486877
08/22/13 03:17 PM
08/22/13 03:17 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Ok guys,I'm going to gasket match and bolt it on. Here is a link to the mechanical 4782/83 for those who are curious. Thanks for the help.
http://www.ford6v.com/ford6vtech/ford6vtech.htm
Re: 340 6 pack intake porting??? [Re: BSB67] #1486878
08/22/13 06:01 PM
08/22/13 06:01 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I looked at my outboard and it has down leg boosters the center carb has down leg but with the tube protruding into the center, the shafts are half, not sure if "slabbed" but there not the round type that the throttle plate sits between, the throttle is metal and only .038 thick. Looks like an old 800 and 850 dp I had .
Re: 340 6 pack intake porting??? [Re: ademon] #1486879
08/22/13 08:55 PM
08/22/13 08:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Interesting. Mine are original 1969 carbs. The boosters are downleg, just larger than on my 4781-2, 850. I also have recently acquired from Holley assembled base plates and they also have the full diameter throttle shaft and thicker plates.
Re: 340 6 pack intake porting??? [Re: ademon] #1486880
08/22/13 09:12 PM
08/22/13 09:12 PM
Original carbs are not the same as the mechanicals in many ways. The 4783 mechanical outer carb does not have the thick throttle plates.
I'll have to remove the front carb from my car to compare the boosters and throttle shaft with a 4781 850dp. I'll be back shortly.
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486881
08/22/13 09:45 PM
08/22/13 09:45 PM
I measured the boosters and they are exactly the same.
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486882
08/22/13 09:49 PM
08/22/13 09:49 PM
Exact same slabbed throttle shaft as 4781. The stamped numbers on the throttle plates are even the same.
I still believe that two 4783s equals one 4781. And then there's the matter of 300 more cfm stuffed in between them.
For those that don't know, the 4782/4783 mechanical carbs were not OEM on anything. They were available over the counter in the 1970's from both Holley and Mopar. They use side hung float bowls to get extra space for full metering blocks. Unlike the OEM carbs, the idle mixture is not adjustable on the outer carbs. Edelbrock supplied the linkage and a fuel log. The linkage and fuel log have not been available for decades and you have to make your own. Fuel lines are an adventure as they are on the wrong side and the front carb fitting interferes with the 70 and up aircleaner base. I had to make 3/8" spacers to raise the base up for clearance. The A12 aircleaner fits fine without spacers.
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486883
08/22/13 10:31 PM
08/22/13 10:31 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
thanks nice info! I know some of the ford stuff I have dug up seems to point to these flowing around a true 1150cfm. I plan on running without the choke plate and rod so add another 40cfm or so to that... LOL. Plan on working the intake, and rebuilding the carbs in the next few weeks hope to have it on and running by October .
Re: 340 6 pack intake porting??? [Re: ademon] #1486884
08/22/13 10:59 PM
08/22/13 10:59 PM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
I have a cast iron 6 pack intake and the aftermarket style carbs for a 440. I have been itching to try them out but Im sure I dont have the hood clearance on my 74 Scamp. Other than jetting would the carbs be the same for a small block? I never really knew the difference between bb and sb six pack carbs. Are rebuild kits still avaliable for the aftermarket carbs?
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486885
08/22/13 11:24 PM
08/22/13 11:24 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Okay, got it. Not originals. I missed that part.
Re: 340 6 pack intake porting??? [Re: mopfried] #1486886
08/22/13 11:28 PM
08/22/13 11:28 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
4782/83 same for bb/sb, Holley just reissued the kit # 37-396. These carbs are kind of popular with the Ford guys also, there is a set on e-bag right now. from what I have been told shouldn't have to change jetting more than a few sizes for any size engine.
Re: 340 6 pack intake porting??? [Re: mopfried] #1486887
08/22/13 11:34 PM
08/22/13 11:34 PM
Yes. Holley, quickfuel, AED, BG all sell kits for 2300 carbs.
http://www.holley.com/37-396.asp
Re: 340 6 pack intake porting??? [Re: GomangoCuda] #1486888
08/23/13 08:30 AM
08/23/13 08:30 AM
Columbus Ohio
mopfried Offline
mopfried  Offline
Columbus Ohio
thanks
