340 6 pack intake porting??? #1486849
08/19/13 05:59 PM
08/19/13 05:59 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I'm going to run a mopar 6 pack intake and was wondering if anyone has some tips, tricks, advise on modifying it to flow better. I'm going to gasket match it as deep as possible other than that not sure what else can be done. I know many have said its fine till around 5,500 rpm but then falls off fast, anyone have any real experience with one?? Thanks.
Re: 340 6 pack intake porting??? [Re: ademon] #1486850
08/19/13 06:25 PM
08/19/13 06:25 PM
Locomotion Offline
Locomotion  Offline
It's a good intake as-is, but a Six Pack is difficult to tune and set-up for optimum performance. Personally I would be afraid to do anything more than smoothing out any imperfections without a flow bench. I do tend to be rather cautious. You can make more HP with a properly tuned carb on a good 4 bbl intake.
Here is an old but interesting article on dynoed small block intakes.
Mopar Muscle Magazine small block intake article.
P.S.: Always look at the "area under the curve", not necessarily peak numbers, for best performance. (It would be easier to understand with a line graph as opposed to a numbers chart.)
Re: 340 6 pack intake porting??? [Re: ademon] #1486851
08/19/13 06:32 PM
08/19/13 06:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Mine is absolutely stock as it came out of the box on my warmed up 340. It will pull further in the RPM range higher than I am willing to rev it. Ive seen mine well above 5000 a few times tho. IMO your vale train may limit your RPM range more than the capabilities of a 6 pac...
I am truckless..
Re: 340 6 pack intake porting??? [Re: Locomotion] #1486852
08/20/13 11:47 AM
08/20/13 11:47 AM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Yes I have seen that before, the 6 pack doesn't do bad at all in the shoot out
yes seen that shoot out before the 6 pack does very well i think with slightly lean carbs
Re: 340 6 pack intake porting??? [Re: 340SHORTY] #1486853
08/20/13 12:25 PM
08/20/13 12:25 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I hit the shifter at 6400 w/o any issues, stock carbs and intake.
Coming soon!!!!
Re: 340 6 pack intake porting??? [Re: Mr.Yuck] #1486854
08/20/13 12:28 PM
08/20/13 12:28 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
Me too!!
Re: 340 6 pack intake porting??? [Re: superwrench] #1486855
08/20/13 02:23 PM
08/20/13 02:23 PM
dogdays Offline
dogdays  Offline
This question belongs on the race page.
I believe that there are improvements to be made to the Six Pack intake, but would want a pro with particular experience to do the job.
R.
Re: 340 6 pack intake porting??? [Re: dogdays] #1486856
08/20/13 02:35 PM
08/20/13 02:35 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
I shift at 6,400 also so that's why I want to get the most out of the intake. Maybe it does belong in the race section although I didn't think this was a hard core race question, I figured I would get the usual " single 4 bbl with a rpm or single plane would be better"
Re: 340 6 pack intake porting??? [Re: ademon] #1486857
08/20/13 03:00 PM
08/20/13 03:00 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
If you want the 6 pack factor then go ahead, want it to run... run an air gap and a decent sized 4 bbl.
I bet if you put the same size CFM single 4 on the air gap as the 6 pack flows in the mag article, the differences would have been even wider. A DP carb instead of that Vac Avenger stuff would have mudholed the 6 pack even more throughout the range.
Don't know if you have a 400+ incher, but, stroker engines I've seen suffer even greater differences than in that article.
The big block intake is a different deal than the SB one...
Re: 340 6 pack intake porting??? [Re: RobX4406] #1486858
08/20/13 03:27 PM
08/20/13 03:27 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
yes kind of know all that, i run a holley strip dominator with a 750 race holley with annular boosters. its a 360 with about 400hp, will stroke it in the future but don't want to run faster than 11.50's not going to put the cage in the demon. this intake will have the mechanical DC carbs on it. just looking for something different than the single 4 bbl that 95% of the cars at the cruise and track have on them.
Re: 340 6 pack intake porting??? [Re: ademon] #1486859
08/20/13 03:32 PM
08/20/13 03:32 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Im sure even with the stock 6 pack and carbs on top of a good 416" i will have no trouble seeing 11.50's and maybe quicker before they toss me out of the strip for no bar.
Re: 340 6 pack intake porting??? [Re: ademon] #1486860
08/20/13 03:41 PM
08/20/13 03:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I think the stock carbs out-flow the mechanicals. FWIW I'm pretty much under 11.50 (unless I blow the tires up) and haven't been asked to leave yet. They key is to put 12.0 @ 115 on your tech card. Usually the guy handing out slips isn't looking inside the car for a cage.
Re: 340 6 pack intake porting??? [Re: Mr.Yuck] #1486861
08/20/13 03:57 PM
08/20/13 03:57 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
there rated at 1355cfm, i know when compared to 4bbl rating i think they are in the 975 cfm range same as the stock vacuum carbs. The manifold ports are quite a bit smaller than the gasket so at the very least i will gasket match them to the heads.
Re: 340 6 pack intake porting??? [Re: ademon] #1486862
08/20/13 04:08 PM
08/20/13 04:08 PM
RobX4406 Offline
RobX4406  Offline
The 6 Pack will be an easy way to slow you down.
Re: 340 6 pack intake porting??? [Re: RobX4406] #1486863
08/20/13 05:22 PM
08/20/13 05:22 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
well so be it!! It's a street car, like any street driven car it will spend 90% of the time under 4k, it will only see the track a few times a year so I'll live with it, and the better mileage. But if I want to pick up a few more tenths I'll toss my ported strip dominator on it, or my worked torker II, or the venerable LD340 I have laying around here somewhere LOL
Re: 340 6 pack intake porting??? [Re: ademon] #1486864
08/20/13 05:29 PM
08/20/13 05:29 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
I shift my AAR at 7000 and it has hit the rev limiter quite a few times set at 7500. My 340 six pack loves to rev. Best time 12.3 @ 109. It slows down if I shift it anywhere lower than 6600 rpms. It has also gone 11.90 with a small shot of nitrous through the 6 pack intake.
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 340 6 pack intake porting??? [Re: ademon] #1486865
08/20/13 06:02 PM
08/20/13 06:02 PM
RobX4406 Offline
RobX4406  Offline
All good, run what you like is the best approach. That isn't always the max performance which is fine.
If 11.50 is you goal, that should not be hard to attain with a decent hooking 360/420-430hp.
Re: 340 6 pack intake porting??? [Re: 11secaarcuda] #1486866
08/20/13 06:14 PM
08/20/13 06:14 PM
IL, Aurora
ademon Offline OP
ademon  Offline OP
IL, Aurora
Nice! Is that the old Eddy intake or the Mopar? I thought I read somewhere that the intake hit a flat spot around 6,200 rpm but then made power again past that if pushed higher.
Re: 340 6 pack intake porting??? [Re: RobX4406] #1486867
08/20/13 07:17 PM
08/20/13 07:17 PM
superwrench Offline
superwrench  Offline
Never say that.....I just ran 10.80's last weekend.
Everyone says that I'd run 10.60's with a good single plane and 4 bbl....not that I don't believe them, but why change when I'm having a blast making mine run quicker and quicker.
Re: 340 6 pack intake porting??? [Re: RobX4406] #1486868
08/20/13 09:49 PM
08/20/13 09:49 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
really? A 6-pack is a good all around unit that is capable of 10's if tuned right. Not to mention they get good MPG's when compaired to BIG 4bbls. If I can get my traction issues worked out I'll be 11.teens or better w/ a stock intake and carbs. Not sure an RPM and single Holley would do a ton better.
