bell housing over spray #148653
11/10/08 09:51 PM
11/10/08 09:51 PM
Ball Ground GA
TrueTripleX Offline OP
Ball Ground GA
Just to make sure, I want an expert answer. 68 383 road runner. Was the bell housing attached to the motor when painted, and was it over sprayed or completely painted? Thanks
Re: bell housing over spray [Re: TrueTripleX] #148654
11/10/08 09:59 PM
11/10/08 09:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You might get a better quicker answer if you posted this in the restoration section.
Re: bell housing over spray [Re: stumpy] #148655
11/10/08 10:24 PM
11/10/08 10:24 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I can't say absolutely but I would think the engine was painted first then attached to the transmission. Tranny shouldn't have any paint on it.
OOps, re-read. I'm not an expert, nor do I play one on TV. It just seems that from what I have seen on auto plant assy, the engines were, built in one area, painted in another, and then sent to the assembly line and attached to the tranny. I'm certain I will be shown the error of my logic however
Re: bell housing over spray [Re: TrueTripleX] #148656
11/10/08 10:34 PM
11/10/08 10:34 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Manual trans , Yes. How much more than likely varied depending on how ambishious the painter was that particular day
