Page 3 of 3 1 2 3
Re: possible state of emergency [Re: Quicktree] #1486482
08/24/13 12:47 PM
08/24/13 12:47 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
good news and bad news
I got the car running last night and it sounds much better. the car got a lot louder than it was, I wouldn't have thought that. I have 17" of vacuum at idle, sounds really responsive
the bad news is my friends that own the dyno, well I had a falling out with one of them and won't be able to go back and see what difference it made which really bums me out. but oh well.
I rechecked the vacuum on the old cam and i was mistakin, it wasn't 28 it was 24"
maybe if it EVER stops raining I will get to drive it.
oh for pete's sake go kiss and make up. friends are hard to find.
I don't have a problem with him, he has a problem with me. one of those guys that asks for free stuff for his car than turns around and sells or trades his car 3 months later. he traded away someones CNC'ed heads.
i know thats ridiculous but he has to live with it. tell him how you feel with out getting into
oh I did, somehow in his mind, 30 hrs of my time equals 3 hours on his dyno
Re: possible state of emergency [Re: sixpackgut] #1486483
08/24/13 01:04 PM
08/24/13 01:04 PM
Q
Quicktree Offline
Quicktree  Offline
Q
he will understand when he doesn't get your help anymore
Re: possible state of emergency [Re: sixpackgut] #1486484
08/24/13 01:05 PM
08/24/13 01:05 PM
Q
Quicktree Offline
Quicktree  Offline
Q
Re: possible state of emergency [Re: sixpackgut] #1486485
08/24/13 03:12 PM
08/24/13 03:12 PM
MN
hemidup Offline
hemidup  Offline
MN
What's the LSA of your new cam? 17" still seem's quite high.
Jerry Williams.
Re: possible state of emergency [Re: hemidup] #1486486
08/24/13 03:23 PM
08/24/13 03:23 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Glad you got it going Ray, see you in BG.
68 Barracuda Formula S 340
Re: possible state of emergency [Re: Bad340fish] #1486487
08/24/13 09:05 PM
08/24/13 09:05 PM
ohio
all spooled up Offline
ohio
glad you stuck with it. good job. tell the dyno guy to f--- off and move on
Re: possible state of emergency [Re: sixpackgut] #1486488
08/24/13 09:44 PM
08/24/13 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good to hear you have it up and running
Re: possible state of emergency [Re: MR_P_BODY] #1486489
08/26/13 01:50 PM
08/26/13 01:50 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I read the text about the pushrods and the power gain. Good to see you're feeling the gain!
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: possible state of emergency [Re: AlexP] #1486490
08/28/13 09:39 PM
08/28/13 09:39 PM
Charleston
Charleston
so Chip sent me a Holley 830 cfm dp,it has power valves front and rear, annular boosters, jet extensions/ notched float. I put new gaskets in it, a 50cc pump on the secondaries and just took it for a ride. it doesn't idle as well as the edelbrock and I don't think it feels as fast but its so silky smooth and with the jets that were in it, looks very close on the A/F meter but most of you know I certainly don't live by that meter
the edelbrock had a slight hesitation when the outboards opened which I was planning on working on but I think Chip's Holley is going to Drag Week. I'm not getting full throttle with the Holley so I need to work on a new throttle cable bracket
the new cam not only sounds better but the car feels a lot stronger, I guess we'll see how it does in a week and a half
Re: possible state of emergency [Re: sixpackgut] #1486491
08/28/13 10:07 PM
08/28/13 10:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cool... glad you got it back together... see you in
BG..
I pulled the heads off my Rampage today... and the set
of W-2s off my other engine... I'm gonna mock them up
tomorrow and measure for push rods... then I want to
tear the W-5s apart to see if I see anything wrong
Re: possible state of emergency [Re: sixpackgut] #1486492
08/29/13 09:18 AM
08/29/13 09:18 AM
an8sec70cuda Offline
Glad my carb is working good for you. I know you'd rather run the Edelbrock, but since you're in a pinch for time maybe you can make an exception this once, lol.
That carb worked great on my old 440...used it for a long time. Do whatever you need to do to it and good luck at DW!!!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: possible state of emergency [Re: an8sec70cuda] #1486493
08/29/13 10:52 AM
08/29/13 10:52 AM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
I have a question? can a DW participate replace max performance carb from the trunk for a fuel mileage carb on the engine, at the track.then back to milage carb for the road?
Re: possible state of emergency [Re: dodger mope] #1486494
08/29/13 10:56 AM
08/29/13 10:56 AM
Yep. I remember that Doc guy w/ the white vette did just that a few years back.
CHIP
Re: possible state of emergency [Re: dodger mope] #1486495
08/29/13 12:16 PM
08/29/13 12:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You can change anything you want.. EXCEPT the block..
the block you start with is the one you finish with..
other than that... you can throw ANYTHING at it
Re: possible state of emergency [Re: MR_P_BODY] #1486496
08/29/13 01:07 PM
08/29/13 01:07 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Shawn Anderson switched between a gasoline carb (for the road) and an E85 carb (track) every day in 2011.
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: possible state of emergency [Re: BBR] #1486497
08/29/13 03:30 PM
08/29/13 03:30 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Get fancy with the carb and you can get good mpg and run well at the track. I came in with a weekly mpg average of over 13mpg and ran in the 11s the whole trip.
I just changed mufflers and it made my tune much more rich though so I will see how that MPG works out this year.
Page 3 of 3 1 2 3
