Page 2 of 3 1 2 3
Re: possible state of emergency [Re: sixpackgut] #1486462
08/19/13 09:13 PM
08/19/13 09:13 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I'm anxious to see how you like the cam. Good luck getting over all the issues.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: possible state of emergency [Re: AlexP] #1486463
08/19/13 10:27 PM
08/19/13 10:27 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Me too, and I would like to know what it is.
Mopar to the bone!!!
Re: possible state of emergency [Re: 72Swinger] #1486464
08/20/13 01:12 AM
08/20/13 01:12 AM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I know, but its top secret.
Re: possible state of emergency [Re: AlexP] #1486465
08/20/13 01:17 AM
08/20/13 01:17 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'm guessing it's pretty tame or that Edelbrock carb is going to be a problem to tune.
Re: possible state of emergency [Re: goldmember] #1486466
08/20/13 01:45 AM
08/20/13 01:45 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I've had to drive the grease fittings in on more than one occasion.
threading them in was not working.
Use a small socket and be sure to keep from dinging the
spring-loaded ball.
Joe
Re: possible state of emergency [Re: jlatessa] #1486467
08/20/13 09:04 AM
08/20/13 09:04 AM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
spring-loaded ball.
Joe
Thanks! I love tech tips in the race section
Re: possible state of emergency [Re: sixpackgut] #1486468
08/20/13 10:23 AM
08/20/13 10:23 AM
an8sec70cuda Offline
Good luck w/ it Ray! Wish I was closer, I'd give you a hand. If there's anything I can do, just give me a holler.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: possible state of emergency [Re: sixpackgut] #1486469
08/20/13 11:11 AM
08/20/13 11:11 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Good to hear you have some parts on the way.. good
luck in getting it all buttoned up... see you in BG
Re: possible state of emergency [Re: MR_P_BODY] #1486470
08/20/13 05:35 PM
08/20/13 05:35 PM
Gilbert AZ
tsanchez Offline
tsanchez  Offline
Gilbert AZ
Good luck!!!!
Re: possible state of emergency [Re: tsanchez] #1486471
08/20/13 11:23 PM
08/20/13 11:23 PM
Charleston
Charleston
need pushrods. its fighting me but not giving up
Re: possible state of emergency [Re: sixpackgut] #1486472
08/21/13 01:24 AM
08/21/13 01:24 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Make it submit! Like them oval lobes
"Just a Bracket car dressed up like a streetcar"
Re: possible state of emergency [Re: Just-a-dart] #1486473
08/21/13 09:11 AM
08/21/13 09:11 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looking at that picture and the fact that I can see the extra duration I can only come to one conclusion. There is no way an edelbrock carb is going to work on there.
68 Barracuda Formula S 340
Re: possible state of emergency [Re: Bad340fish] #1486474
08/21/13 09:49 AM
08/21/13 09:49 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Oh yea those afb, avs, edelbrock are just horrible. I am supprised the NSS cars, Maxi Stockers and so forth will even get to the starting line under their own power. Lol How about the stock class dart that runs low 10's with a single 440 avs. You can tune that design carburator and they work much better than most give them credit for. Steve Wann has run 9.70 in SS with a single AVS.
Getting old just means you were smarter than some and luckier than others.
Re: possible state of emergency [Re: dannysbee] #1486475
08/21/13 01:13 PM
08/21/13 01:13 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Nothing against them as far as tunability goes when using two of them, but those carbs are not stock out of the box carbs the SS guys use and many of the metering rods in them are closely guarded secrets. I assure you when I ran a pair of them on my Hemi, what the engine wanted, and what is available in their tuning kit is night and day different. I was to the point of making my own on a lathe to accomidate what the engine wanted. If they had an all togather seperate idle circuit, they would be better.
You can however order custom ones from certain suppliers that will get them to work better, but limited to a single carb really restricts options. Once I drilled the quirters out big enough to get rid of the bog, I ran out of fuel in the bowl. And the rods never had the right combinations, so it takes more than just tinkering to sort them out.
I am rooting for him, and he had two of these working very well on his RB engine, so I am curious to see...So keep up the work, and I very much want to see him succeed here. Especially taking on a new challenge of a new engine like this after having won last year with his previous combo...Been wanting one of these engines as well, but they are initially cost prohibitive to replace the older generation engines with.
I do have an 850 Proform I can send you if you want to try it, at NO CHARGE. It has all the air bleeds for adjustability, and you are welcome to it. I would put it on the dyno and tweek it a little as I have not had enough time to get it where I would like, but its up to you.
Re: possible state of emergency [Re: Just-a-dart] #1486476
08/21/13 01:13 PM
08/21/13 01:13 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
I sent him to Steve for this cam. The results will be good.
Re: possible state of emergency [Re: AlexP] #1486477
08/24/13 10:42 AM
08/24/13 10:42 AM
Charleston
Charleston
good news and bad news
I got the car running last night and it sounds much better. the car got a lot louder than it was, I wouldn't have thought that. I have 17" of vacuum at idle, sounds really responsive
the bad news is my friends that own the dyno, well I had a falling out with one of them and won't be able to go back and see what difference it made which really bums me out. but oh well.
I rechecked the vacuum on the old cam and i was mistakin, it wasn't 28 it was 24"
maybe if it EVER stops raining I will get to drive it.
Re: possible state of emergency [Re: sixpackgut] #1486478
08/24/13 10:43 AM
08/24/13 10:43 AM
Q
Quicktree Offline
Quicktree  Offline
Q
oh for pete's sake go kiss and make up. friends are hard to find.
Re: possible state of emergency [Re: sixpackgut] #1486479
08/24/13 11:00 AM
08/24/13 11:00 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
that side by side is impressive! I need to get with the times and get a roller
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: possible state of emergency [Re: Quicktree] #1486480
08/24/13 11:32 AM
08/24/13 11:32 AM
Charleston
Charleston
I don't have a problem with him, he has a problem with me. one of those guys that asks for free stuff for his car than turns around and sells or trades his car 3 months later. he traded away someones CNC'ed heads.
Re: possible state of emergency [Re: sixpackgut] #1486481
08/24/13 11:38 AM
08/24/13 11:38 AM
Q
Quicktree Offline
Quicktree  Offline
Q
i know thats ridiculous but he has to live with it. tell him how you feel with out getting into
Page 2 of 3 1 2 3
