Re: possible state of emergency
[Re: Quicktree]
#1486482
08/24/13 12:47 PM
08/24/13 12:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
good news and bad news
I got the car running last night and it sounds much better. the car got a lot louder than it was, I wouldn't have thought that. I have 17" of vacuum at idle, sounds really responsive
the bad news is my friends that own the dyno, well I had a falling out with one of them and won't be able to go back and see what difference it made which really bums me out. but oh well.
I rechecked the vacuum on the old cam and i was mistakin, it wasn't 28 it was 24"
maybe if it EVER stops raining I will get to drive it.
oh for pete's sake go kiss and make up. friends are hard to find.
I don't have a problem with him, he has a problem with me. one of those guys that asks for free stuff for his car than turns around and sells or trades his car 3 months later. he traded away someones CNC'ed heads.
i know thats ridiculous but he has to live with it. tell him how you feel with out getting into
oh I did, somehow in his mind, 30 hrs of my time equals 3 hours on his dyno
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1486483
08/24/13 01:04 PM
08/24/13 01:04 PM
Quicktree
he will understand when he doesn't get your help anymore
[Re: sixpackgut]
#1486484
08/24/13 01:05 PM
08/24/13 01:05 PM
Quicktree
[Re: sixpackgut]
#1486485
08/24/13 03:12 PM
08/24/13 03:12 PM
Posts: 833 MN
hemidup
MN
What's the LSA of your new cam? 17" still seem's quite high.
Jerry Williams.
[Re: hemidup]
#1486486
08/24/13 03:23 PM
08/24/13 03:23 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Glad you got it going Ray, see you in BG.
68 Barracuda Formula S 340
[Re: AlexP]
#1486490
08/28/13 09:39 PM
08/28/13 09:39 PM
sixpackgut
Charleston
so Chip sent me a Holley 830 cfm dp,it has power valves front and rear, annular boosters, jet extensions/ notched float. I put new gaskets in it, a 50cc pump on the secondaries and just took it for a ride. it doesn't idle as well as the edelbrock and I don't think it feels as fast but its so silky smooth and with the jets that were in it, looks very close on the A/F meter but most of you know I certainly don't live by that meter
the edelbrock had a slight hesitation when the outboards opened which I was planning on working on but I think Chip's Holley is going to Drag Week. I'm not getting full throttle with the Holley so I need to work on a new throttle cable bracket
the new cam not only sounds better but the car feels a lot stronger, I guess we'll see how it does in a week and a half
[Re: sixpackgut]
#1486491
08/28/13 10:07 PM
08/28/13 10:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Cool... glad you got it back together... see you in BG.. I pulled the heads off my Rampage today... and the set of W-2s off my other engine... I'm gonna mock them up tomorrow and measure for push rods... then I want to tear the W-5s apart to see if I see anything wrong
[Re: sixpackgut]
#1486492
08/29/13 09:18 AM
08/29/13 09:18 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
Glad my carb is working good for you. I know you'd rather run the Edelbrock, but since you're in a pinch for time maybe you can make an exception this once, lol. That carb worked great on my old 440...used it for a long time. Do whatever you need to do to it and good luck at DW!!!
[Re: dodger mope]
#1486494
08/29/13 10:56 AM
08/29/13 10:56 AM
an8sec70cuda
I have a question? can a DW participate replace max performance carb from the trunk for a fuel mileage carb on the engine, at the track.then back to milage carb for the road?
Yep. I remember that Doc guy w/ the white vette did just that a few years back.
[Re: dodger mope]
#1486495
08/29/13 12:16 PM
08/29/13 12:16 PM
MR_P_BODY
You can change anything you want.. EXCEPT the block.. the block you start with is the one you finish with.. other than that... you can throw ANYTHING at it
[Re: MR_P_BODY]
#1486496
08/29/13 01:07 PM
08/29/13 01:07 PM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
Shawn Anderson switched between a gasoline carb (for the road) and an E85 carb (track) every day in 2011.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#1486497
08/29/13 03:30 PM
08/29/13 03:30 PM
Bad340fish
Tulsa OK
Get fancy with the carb and you can get good mpg and run well at the track. I came in with a weekly mpg average of over 13mpg and ran in the 11s the whole trip.
I just changed mufflers and it made my tune much more rich though so I will see how that MPG works out this year.
