E body vrs B body K frame/steering box angle #1486346
08/18/13 07:33 PM
08/18/13 07:33 PM
Ky
jt4406 Offline OP
jt4406  Offline OP
Ky
I remember reading a post a while back about someone with a question about the steering box angle, E body vrs B body. I have attached a pic of my steering box mounted up with a set of what appear to be alignment shims on the top two bolts. I believe these to be original to the car and wonder if anyone else has found these on E bodies they have disassembled. Thought they may explain the question of different steering box angles E body vrs B body.
jess in ky
Yeah, it's hopped up to over 160...
Re: E body vrs B body K frame/steering box angle [Re: jt4406] #1486347
08/18/13 08:15 PM
08/18/13 08:15 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I doubt they are original because the bolt is not.
Re: E body vrs B body K frame/steering box angle [Re: jt4406] #1486348
08/18/13 08:33 PM
08/18/13 08:33 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
E body was the same as 71 B body, but 70 and back B body's were different.
Re: E body vrs B body K frame/steering box angle [Re: 71birdJ68] #1486349
08/18/13 10:25 PM
08/18/13 10:25 PM
california
Mr D21 Offline
Mr D21  Offline
california
I found 2 shims on my 70 challenger when I took it a part. I assumed it was put there by the factory / dealership to fix some angle issue.
Re: E body vrs B body K frame/steering box angle [Re: Challenger 1] #1486350
08/18/13 11:00 PM
08/18/13 11:00 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
They switched to a hex head sometime in the 70s, but my 70 had that style from the factory.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: E body vrs B body K frame/steering box angle [Re: Silver70] #1486351
08/19/13 02:46 AM
08/19/13 02:46 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
My 70 Charger had 12 point headed bolts. Yesterday I pulled a steering chuck from a 68 Plymouth wagon. It also had 12 point headed bolts. Maybe they used them because of limited clearance?
Re: E body vrs B body K frame/steering box angle [Re: Kern Dog] #1486352
08/19/13 02:57 AM
08/19/13 02:57 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I should have said 6 point head... but by 72 I'd say, they have the 6 point style. May have started in 71, but haven't messed with too many 71s to know for sure.
I doubt it was clearance related. Probably cost/availability or maybe the 6 point style were stronger
