383 oil pressure problems
#1485497
08/17/13 03:47 AM
08/17/13 03:47 AM
Posts: 2,782 USA
JoesMopar
USA
I have a rebuilt 383 in my Road Runner that has had zero problems for over a year.
Tonight, I noticed the oil pressure gauge starting to fluctuate much more, and in some instances, drop to zero. It's a cheapo mechanical gauge.
I noticed when I floored the car and wound out each gear, the pressure would want to back off at higher rpms, before each gear change (727). A couple of times when I started the car up, there was NO oil pressure and it took 5-10 seconds for the pressure to come up, however I didn't hear the engine get any noisier than usual (Comp XE cam and lifters). A few times the pressure would just fluctuate wildly.
I was going up a small hill, got on the gas a little, and the pressure dropped to zero, again, with no extra noise for about 5-10 sec and came back up.
It's as if these problems came out of nowhere. I'm concerned something serious might be wrong. I thought about the pressure relief valve, but I can't convince myself and was just wondering what you guys think. Like I said, it has NEVER done this before and I'm not sure if a mechanical gauge can just crap out or not.
When the car is in park or neutral and hot, it runs about 25 psi. I can rev it up and it will immediately jump to ~50 psi. When I'm cruising it runs right around 50psi as well. I'm running Rotella 15w-40 (with zinc additive) and a Napa Gold 1515 filter, stock pan w/windage tray (402 iirc) and std oil pump.
Thanks for any help
Re: 383 oil pressure problems
[Re: JoesMopar]
#1485498
08/17/13 04:17 AM
08/17/13 04:17 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
low oil level, failing gauge, bad connection at the sending unit, bad sending unit......
I am truckless..
[Re: JoesMopar]
#1485499
08/17/13 09:46 AM
08/17/13 09:46 AM
RapidRobert
Yes I'd put on a good gauge & see it that's it. After that if still no go I'd think (1) pickup too close to pan or way too much clearance (2) partly plugged pickup (less likely) (3) reg issue (less likely). I'm thinking it's the gauge. Holler how it goes
[Re: JoesMopar]
#1485503
08/17/13 04:37 PM
08/17/13 04:37 PM
Posts: 15,457 Omaha Ne
TJP
Omaha Ne
Step 1 verify the gauge. Step 2 Change the oil filter Step 3 change the oil pump.
[Re: Supercuda]
#1485506
08/18/13 01:14 AM
08/18/13 01:14 AM
Posts: 172 IL,USA
bdusted440
IL,USA
And put gas engine oil in it not diesel oil. From exp at the dealer diesel oil eats at the babit on the bearings of gas engines. Diesel bearings are different. Our lube guy put the wrong oil in a ram and it cost the dealer an engine.My .02
currently own 1976 duster deluxe 1974 gold duster 1993 Dakota sport 2000 caravan 2002 Durango 1970 v code superbee
[Re: JoesMopar]
#1485512
08/22/13 12:23 PM
08/22/13 12:23 PM
TJP
Omaha Ne
Well, I checked my oil, which I do on a regular basis, and it was a quart low. I know it's leaking from the sending unit that I can't get to seal. Last time I checked it was a little more than 1/2 a quart low but I was planning on changing the oil soon and didn't bother to add any. I threw a quart in this evening, brought it right back to full and the problem disappeared. I think I may have the pickup a little further from the pan than it needs to be. I'm not going to take the pan off to check, I'm going to just not be so lazy, or cheap, and keep it filled....or better yet...finally fix the leaky sending unit.
What you are describing is a situation in which the motor has been starved for oil specifically under load at higher RPM's YIKES!!!! I'm going to just not be so lazy, or cheap, and keep it filled....or better yet...finally fix the leaky sending unit. I would suggest verifying that it is the pickup. this could probably be accomplished by draining the oil and looking in through the drain hole with an good light or inspection camera. If it is too far off the floor of the pan I would drop the pan and fix it before you lose the bearings. Overfilling it by adding an extra quart is a band aid that could lead to other consequences
