Is this flywheel for a steel or cast crank? #1485423
08/16/13 11:25 PM
08/16/13 11:25 PM
Brantford Ontario
69_SIX_PACK Offline OP
Brantford Ontario
I think I messed up here, bought this 143 tooth 11 inch flywheel...I didn't even notice the chunk that machined out...does that make it for a cast crank???
I need a steel crank flywheel...if its wrong I will try and unload it at Moparfest this weekend.
Thanks!
Re: Is this flywheel for a steel or cast crank? [Re: 69_SIX_PACK] #1485424
08/17/13 12:19 AM
08/17/13 12:19 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That small a cut may be enough to just make it neutral , it wouldn't cost you a bunch to have it made neutral and it would be a good idea to have even a known neutral wheel checked.
Just an FYI , other than maybe some obscure truck application I'm pretty sure only 68-69 Big blocks got 143 tooth wheels and they were all internal balance.
Re: Is this flywheel for a steel or cast crank? [Re: JohnRR] #1485425
08/17/13 12:25 AM
08/17/13 12:25 AM
Brantford Ontario
Brantford Ontario
Thanks John, I appreciate the quick response.
