AVS carb ID #1485144
08/15/13 10:40 PM
08/15/13 10:40 PM
Iowa
burdar Online work OP
Owen's Dad
burdar  Online Work OP
Owen's Dad
Iowa
J9 4933S
I think I asked about this once before but I can't remember what it is. I think it might be a 4-speed carb.
What is different about an auto and a 4-speed carb? Will a 4-speed carb work with an auto?
What is the CFM rating of this carb? Is it generally just for restoration use or can it be used in a mild performance application?
Re: AVS carb ID [Re: burdar] #1485145
08/15/13 10:53 PM
08/15/13 10:53 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
1970 340 manual trans Assembled in September of 1969. CFM was around 600 (factory rating was 630 or so)
Re: AVS carb ID [Re: ScottSmith_Harms] #1485146
08/16/13 11:04 AM
08/16/13 11:04 AM
Iowa
Owen's Dad
Owen's Dad
Iowa
So are the linkages different between the manual and auto carbs?
Should I have this one redone for use on a 330hp 360 or stick with my thermoquad?
Re: AVS carb ID [Re: burdar] #1485147
08/16/13 11:08 AM
08/16/13 11:08 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
No all the same throttle linkage. The TQ will likely make more power and run more efficiently.
Re: AVS carb ID [Re: ScottSmith_Harms] #1485148
08/16/13 11:09 AM
08/16/13 11:09 AM
Iowa
Owen's Dad
Owen's Dad
Iowa
Thanks Scott
