727 What trans fluid? #1485048
08/15/13 03:43 PM
08/15/13 03:43 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
I checked 15 pages of current posts and the Archives first.
Stock 727 in a '78 pickup (360 2 bbl) was way low on fluid, only Dexron III available so that was used to get it down the road. Within that 30 mile trip it developed a slight vibration about 35mph (possibly not related to trans at all but mentioning just in case) and I could smell "hot trans". Couldn't quite tell if it was hot bands or fluid leaking on exhaust.
Going out today to drop the pan and have a look inside. What fluid are you guys using now? Stick says Dexron II, I've been told Type F because it provides better grip on the bands and of course Mopar ATF 3/4.
Guide me oh wise ones.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 727 What trans fluid? [Re: Cheeto] #1485049
08/15/13 04:25 PM
08/15/13 04:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Any of the current Dexron will be OK as will type F. ATF 3/4 is for OD transmissions.
Re: 727 What trans fluid? [Re: John_Kunkel] #1485050
08/15/13 08:07 PM
08/15/13 08:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Good to see you still around.
Dextron is the recomended fluid for Mopars.
I hear that the type F is the same stuff that B&M sells as "Trick Shift fluid. It is supposed to give firmer shifts.
I am truckless..
Re: 727 What trans fluid? [Re: 340SHORTY] #1485051
08/15/13 09:29 PM
08/15/13 09:29 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Used only Type F in my '68 rr and funny how it is getting hard to find a national auto parts chain to carry more than about six bottles of it at a time did firm up the shifts
Re: 727 What trans fluid? [Re: A12] #1485052
08/15/13 10:26 PM
08/15/13 10:26 PM
ill
dennismopar73 Offline
ill
What ever fluid you like, or what hits the pocket book, but sounds as if your trans needs a rebuild??
Re: 727 What trans fluid? [Re: dennismopar73] #1485053
08/16/13 02:14 AM
08/16/13 02:14 AM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
... sounds as if your trans needs a rebuild??
This is what I'm afraid may be the case. I dropped the pan and it didn't smell horrible so I threw in a new filter and I just topped it off with Dex/Mercon from Wally World ($17/gal). I'll road test tomorrow and see how it does.
Thanks for the info guys.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 727 What trans fluid? [Re: Cheeto] #1485054
08/16/13 09:48 AM
08/16/13 09:48 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
did you adjust the bands when you had the pan off??
I am truckless..
Re: 727 What trans fluid? [Re: 340SHORTY] #1485055
08/16/13 03:07 PM
08/16/13 03:07 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
Realized this morning that I didn't .
I have 2 choices when doing this stuff:
1)Work in near-constant pain and maybe forget a step.
2)Work under the influence of painkillers and maybe forget a step.
At least I'm only out a couple quarts of fluid since I was "leak-checking" my fabbed up drain plug prior to filling fluid.
Guess I better
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 727 What trans fluid? [Re: Cheeto] #1485056
08/16/13 03:43 PM
08/16/13 03:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I understand the pain thing Joe. Since I took a fall and didnt boune right in Jan 2011 Im in the same situation...
I am truckless..
Re: 727 What trans fluid? [Re: 340SHORTY] #1485057
08/16/13 06:49 PM
08/16/13 06:49 PM
ID/MT
Cheeto Offline OP
Cheeto  Offline OP
ID/MT
took a fall and didn't bounce right
Sorry but that just makes me giggle.
Finished with the help of a lot of cursing, need to go get more ATF and road test...with fingers crossed.
A hoist has moved even farther up my "wish list".
Cheeto
It's not perfect.
It's not correct.
It's not yours!
Re: 727 What trans fluid? [Re: Cheeto] #1485058
08/16/13 08:01 PM
08/16/13 08:01 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I have a friend that sells and installs them..
I am truckless..
