727 What trans fluid?
#1485048
08/15/13 03:43 PM
08/15/13 03:43 PM
Posts: 1,970 ID/MT
Cheeto
ID/MT
I checked 15 pages of current posts and the Archives first. Stock 727 in a '78 pickup (360 2 bbl) was way low on fluid, only Dexron III available so that was used to get it down the road. Within that 30 mile trip it developed a slight vibration about 35mph (possibly not related to trans at all but mentioning just in case) and I could smell "hot trans". Couldn't quite tell if it was hot bands or fluid leaking on exhaust. Going out today to drop the pan and have a look inside. What fluid are you guys using now? Stick says Dexron II, I've been told Type F because it provides better grip on the bands and of course Mopar ATF 3/4. Guide me oh wise ones.
Cheeto It's not perfect. It's not correct. It's not yours!
Re: 727 What trans fluid?
[Re: Cheeto]
#1485049
08/15/13 04:25 PM
08/15/13 04:25 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Any of the current Dexron will be OK as will type F. ATF 3/4 is for OD transmissions.
[Re: John_Kunkel]
#1485050
08/15/13 08:07 PM
08/15/13 08:07 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Good to see you still around. Dextron is the recomended fluid for Mopars. I hear that the type F is the same stuff that B&M sells as "Trick Shift fluid. It is supposed to give firmer shifts.
I am truckless..
[Re: Cheeto]
#1485054
08/16/13 09:48 AM
08/16/13 09:48 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
did you adjust the bands when you had the pan off??
I am truckless..
