92 W150 radiator #1485028
08/15/13 03:01 PM
08/15/13 03:01 PM
California
Hotlumpy Offline OP
Hotlumpy  Offline OP
California
Factory radiator on my 92 w150 worked well until it cracked, replaced it with an off brand of same size, but factory is 1 row, and it doesn't like towing. The truck is equipped with a/c, does anyone know if there was a better option from the factory with more rows, or maybe a good replacement?
Re: 92 W150 radiator [Re: Hotlumpy] #1485029
08/15/13 06:59 PM
08/15/13 06:59 PM
scratchnfotraction Offline
you can use a 86 D-250 rad for max cooling package.
it is same width but taller, all brass/copper/3 row
it will take it own fan shroud which is all metal for the larger rad core.
I also have had good luck with a replacment rad from napa, it is all brass/copper/3 row stock truck size.
I have a plastic alum rad in my 85 truck from advanced auto, it works ok..it has alum core with single row tubes, but wide flat tubes.
I also use a HD thermo clutch with a 7 blade fanwith the stock shroud.
I have a large 3/4 ton rad in the shed that is new, I will look and see if there is a part # on it.
