Re: Carb question-UREMCO carbs from Summit
[Re: dogdays]
#1485025
08/15/13 04:09 PM
08/15/13 04:09 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
So, SSH, What is the largest carb that will fit under the 273's air cleaner? 4 5/8" diameter air horn is the opening limit, the largest stock AFB's are roughly 600cfm, most are less.
How difficult is it to find a "real" 273 carb? Finding one might take some searching
How much would it cost the OP to have you do such a carb? Or the largest carb mentioned above? I will restore any customer supplied good core AFB to "like new" condition for $399.00. I can also build clones just like my Hemi clones which will have as much as 800 cfm, they are based on new style Edelbrock AVS carb bases with vintage 4 5/8" tops. This way you can still use your original air cleaner, all other stock parts fit as they should, you get a carb that looks and runs as good as a new one and uses readily available modern jets and rods. These are $599.00 plus shipping, built to order.
I am assuming the OP wants it to "look" original, but I don't believe he's talking about looking original to a concours judge. So what's the best way to go to feed that 360 and still keep it looking like a 273 to the casual bystander? The clones I mentioned above
Would it be possible to modify the stock air cleaner base to work with the later larger OD airhorns? Sure, anything can be hacked up, but I wouldn't do that to an original 273 air cleaner
[Re: hemidart1]
#1485026
08/16/13 02:52 AM
08/16/13 02:52 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
4131's are plentiful. They are small tops and were designed to feed a 383 to 440. They might be kind of small on the CFM's. Maybe 500?
That carb in the ad? Read that might not look like the actual unit.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
