'worse' gas this summer (Chicago) #1484951
08/15/13 12:04 PM
08/15/13 12:04 PM
IL
furious70 Offline OP
IL
I'm having trouble this summer with my Fury lean surging when I get above 2500rpm and light throttle. I haven't had a chance to log while driving down the road, but I haven't changed anything in the fuel tables for some time in that area so unless the gas has gotten 'worse' or it's moved from E5-10 to E15 I'm at a loss? Anyone else having issues this summer?
(twin turbo EFI 383)
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 'worse' gas this summer (Chicago) [Re: furious70] #1484952
08/15/13 12:18 PM
08/15/13 12:18 PM
dogdays Offline
dogdays  Offline
Rahm Emanuel.
The root of all your problems.
R.
Re: 'worse' gas this summer (Chicago) [Re: furious70] #1484953
08/15/13 12:26 PM
08/15/13 12:26 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Rich-en it up and your lean surge will go away. It also makes your motor run hotter.
Yup the more ethanol in the gas the richer it needs to be, screwing your gas mileage but good.
Re: 'worse' gas this summer (Chicago) [Re: Challenger 1] #1484954
08/15/13 12:35 PM
08/15/13 12:35 PM
IL
IL
This engine actually ran ok down the road at 15:1 A/R and 50* timing when I first got it running on EFI back in 2009. Then I had to change it all to 14.5:1 a year or 2 ago. Looks like I need to try 14.25:1 to see if that's just enough.
70 Sport Fury
68 Charger
69 Coronet
72 RR
