Turn signal problem #1484803
08/15/13 05:37 AM
08/15/13 05:37 AM
Essex, Ont., Canada
Fishmarket Offline OP
Essex, Ont., Canada
On my 71 road runner, the signals work fine when engaged, however after a period of time the right signal gradually starts glowing...not full brightness, but close. All right side signals glow including the dash. I can use the signal without issue but the glowing lamp comes back quicker, it seems, as the car gets warmer??
Any thoughts?
1972 Plymouth Cuda 340 4 speed 1971 Plymouth Road Runner 383 Auto 1970 Plymouth Duster /6 Auto
Re: Turn signal problem [Re: Fishmarket] #1484804
08/15/13 10:14 AM
08/15/13 10:14 AM
Any thoughts?
First I'd replace the flasher can, the one for the turn signals not the one for the hazard flashers. Get an electronic one & the replacement ones sold these days may be mostly electronic but check on that.
Re: Turn signal problem [Re: Fishmarket] #1484805
08/15/13 10:19 AM
08/15/13 10:19 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I had simular problem in my 71 challenger when I had the wiring for the side marker and front parking light switched up. Had the side marker plugged into the front parking light plug.
