e-85 guys jet ?? #1484628
08/14/13 09:41 PM
08/14/13 09:41 PM
ohio
all spooled up Offline OP
ohio
you guys running e-85 4150 holleys what size jets you running with power valve in front pluged in rear
Re: e-85 guys jet ?? [Re: all spooled up] #1484629
08/14/13 09:52 PM
08/14/13 09:52 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
what size carb..and PVRC...?
what metering blocks are you using?
Tony
70 AARCuda Vitamin C
Re: e-85 guys jet ?? [Re: all spooled up] #1484630
08/14/13 10:07 PM
08/14/13 10:07 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I run 93 square in mine, but that doesn't mean 93s will work in your set up. Displacement, cam grind, heads, carb and many other factors influance jet size.
Re: e-85 guys jet ?? [Re: all spooled up] #1484631
08/14/13 10:16 PM
08/14/13 10:16 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
A few years back when I tried E 85, I used the 30% formula. You'll normally use 30% more fuel with E 85 to make it work. I increased all fuel metering by 30%. I decreased all air metering by 30%. This worked for me as my ET and MPH were very close with E85 as with 93 pump gas. I tried E85 mainly for the lower price and to prove to myself that I could make it work. Once the price started to go up, I went back to 93 pump gas.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: e-85 guys jet ?? [Re: 68LAR] #1484632
08/14/13 10:27 PM
08/14/13 10:27 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
86 front / 110 rear, blow through E85
Re: e-85 guys jet ?? [Re: 70AARcuda] #1484633
08/14/13 11:09 PM
08/14/13 11:09 PM
PA
ajcasini Offline
ajcasini  Offline
PA
Same questions but also what is engine combo.
Baseline I use on 750 holley
28 HSB
58IAB
86 - 88 PMJ
76 PVCR
96 - 98 SMJ
blocked
Also is is with .172 downlegs boosters.
