Passing gear #1484620
08/14/13 09:29 PM
08/14/13 09:29 PM
Maryland
moparmd Offline OP
moparmd  Offline OP
Maryland
Can't get adjustment right on Carb kickdown to engage passing gear.
Re: Passing gear [Re: moparmd] #1484621
08/14/13 09:35 PM
08/14/13 09:35 PM
shorten the rod. keep track of the # of turns so you can return to your baseline (if need be)
Re: Passing gear [Re: moparmd] #1484622
08/14/13 09:40 PM
08/14/13 09:40 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
How about doing it the way the service manual calls for. You get that stuff out of whack, you can burn up the trans.
Re: Passing gear [Re: 71birdJ68] #1484623
08/14/13 09:46 PM
08/14/13 09:46 PM
Maryland
moparmd Offline OP
moparmd  Offline OP
Maryland
Don't have service manual have 67 cuda 273 auto. how does the service manual say to do it?
Re: Passing gear [Re: RapidRobert] #1484624
08/14/13 10:32 PM
08/14/13 10:32 PM
Kirkland, Washington
Pacnorthcuda Offline
Actually he would want to lengthen the rod. You want to tell the transmission your foot is more-to-the-floor. That will increase shift points, and increase frequency of downshifting to 2nd.
Re: Passing gear [Re: Pacnorthcuda] #1484625
08/14/13 11:15 PM
08/14/13 11:15 PM
Yep I was backwards
Re: Passing gear [Re: 71birdJ68] #1484626
08/15/13 12:16 AM
08/15/13 12:16 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
If the linkage is stock, you put a #2 screw driver through the holes in the bel crank. Then if someone can look it up for you, you adjust the rod ends per what they say.But the bel crank needs to be where it needs to be.Thats the way they designed the system to work.
Re: Passing gear [Re: moparmd] #1484627
08/15/13 04:34 PM
08/15/13 04:34 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
First off, does it have the stock carb or aftermarket? If aftermarket, you need the correct Mopar throttle lever extension to make the linkage work correctly.
