Hidden headlight doors slamming shut #1484516
08/14/13 05:18 PM
08/14/13 05:18 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
I finally got a relay wired in so the hidden headlights on our 72 charger open and close when you turn the lights on and off.
Now they seem to open slow and smooth yet when they close they come down fast and hard.
Is this normal or is there some way I can adjust the motor or rods or something so they operate smoothly in both directions?
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484517
08/14/13 05:27 PM
08/14/13 05:27 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
There should be some rubber bumpers that handle some of that problem
Re: Hidden headlight doors slamming shut [Re: dart4forte] #1484518
08/14/13 05:39 PM
08/14/13 05:39 PM
BROOK PARK, OH
BROOK PARK, OH
Yes, but as fast and hard as these doors are coming down they help much.
I'm afraid they're going to get broken off if this keeps up like this.
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484519
08/14/13 05:43 PM
08/14/13 05:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Do you have the torsion springs installed on each headlite door?,if so are they tensioned properly so they assist (unwind) the door in lifting/opening, the spring must wind up as the door closes, this way the door has some resistance going down, could be the springs are fatigued?
Re: Hidden headlight doors slamming shut [Re: DAYCLONA] #1484520
08/14/13 05:51 PM
08/14/13 05:51 PM
BROOK PARK, OH
BROOK PARK, OH
There is a spring on the drivers side but not the passengers side.
I have no way of knowing if it's adjusted properly though.
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484521
08/14/13 05:54 PM
08/14/13 05:54 PM
BROOK PARK, OH
BROOK PARK, OH
Ok, I just looked at it and I guess there is no adjustment for the spring.
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484522
08/14/13 06:44 PM
08/14/13 06:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The spring is "adjusted" by removing the rear tang of the spring off it's stop, and winding it by hand while still on the pivot, and reinstalling the tang under the stop while under tension, with the door held in the closed position, you'll need to remove the V clip on the pivot to remove the drive rod from the motor, out of the slot on the pivot, so that you can set up the spring, then activate the door by hand to see how much tension you have in the up position, and how much resistance you have in the down position, you may need to wind/unwind and reset the spring(s) several times to achieve the desired results opening and closing the doors to your satisfaction,...some Chargers 71-2 have 1 or 2 spring set ups, don't know why?, but that's what I've seen over the years
Re: Hidden headlight doors slamming shut [Re: DAYCLONA] #1484523
08/14/13 06:53 PM
08/14/13 06:53 PM
BROOK PARK, OH
BROOK PARK, OH
So it's not uncommon to have a srping on one side and not the other?
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484524
08/14/13 07:02 PM
08/14/13 07:02 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Generally there's 2,...but I have seen cars with only 1 spring set up, and not just Chargers, but Chrysler 300's as well with shutter lites....if the other door has provisions for a spring, add it, or make provisions for a spring if desired, as the cast doors of the 71/2 Chargers are heavy, the springs are the same either side, and install the same way
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484525
08/14/13 07:08 PM
08/14/13 07:08 PM
BROOK PARK, OH
BROOK PARK, OH
I swapped the spring from the drivers to the passenger side and that seemed to help a bit.
I can't for the life of me get another full wrap of tension on the spring though.
Perhaps I just need a new spring or maybe a new one for each side.
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484526
08/14/13 07:20 PM
08/14/13 07:20 PM
BROOK PARK, OH
BROOK PARK, OH
DO you happen to know of anyplace that has the right style of spring?
Re: Hidden headlight doors slamming shut [Re: WILD BILL] #1484527
08/14/13 07:21 PM
08/14/13 07:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Another spring would help, but to my knowledge only good used is available, I don't think anyone is rebopping them?, and the 71/2 Charger springs are just that 71/2 Charger, the other Chrysler models are too large, although they might work?
Member Daytona R/T SE (Mike) over at DodgeCharger.com has a pretty good stash of 71/2 grilles/parts, try PM him over there?
Mike
Re: Hidden headlight doors slamming shut [Re: DAYCLONA] #1484528
08/15/13 04:33 PM
08/15/13 04:33 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I think it's how the work, do they open up or down? When they go down, the weight of those lids helps them "close", and going up is slower.
The Magnums have the same setup, except when they open they drop, but these are plastic and not nearly as heavy. This might be why the "clunk" when they drop.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
