Best long tubes for 70 440 Charger? #1484512
08/14/13 04:49 PM
08/14/13 04:49 PM
MN.
Tim S. Offline OP
Tim S.  Offline OP
MN.
Buddy bought 2 sets from hooker and neither fits. Any recommendations?
Re: Best long tubes for 70 440 Charger? [Re: Tim S.] #1484513
08/14/13 05:10 PM
08/14/13 05:10 PM
MB,CAN
PC-CHARGER Offline
PC-CHARGER  Offline
MB,CAN
I used Doug's headers on my '70 Charger with a 440. Not one ding required and they fit perfectly. I don't believe they are equal length but for my needs, they didn't need to be. D452 I think was the part number.
Re: Best long tubes for 70 440 Charger? [Re: Tim S.] #1484514
08/14/13 05:42 PM
08/14/13 05:42 PM
Charlotte, NC
Orange_Crush Offline
Belieber!
Belieber!
Charlotte, NC
How about TTI? Expensive, but everything I've heard says they always fit.
1970 Dodge Charger R/T Hemi Orange U-code 4-speed
1971 Jaguar E-Type Series 3 V-12 4-speed 2+2 Signal Red.
Re: Best long tubes for 70 440 Charger? [Re: Orange_Crush] #1484515
08/14/13 08:12 PM
08/14/13 08:12 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I've used both the TTI and Doug's 2" tube w/3.5" collector on 440s. The Doug's seem to be a bit higher build quality and fit better at the head, but the TTI don't sit nearly as low under the car. They both sound bitchen with an x pipe and Dynomax Hemi Super Turbos. I'd sure like to see a dyno shoot out between them. Here's some pics of new TTI vs 7 year old Doug's -
TTI - Note the dent for spark plug clearance and squared off pipe at flange
Doug's D452 Not sure why Doug's does a full length weld at the flange to pipe seam and TTI does a short weld. Doug does not dent for plug clearance, but will BBQ plug caps if you don't use insulators.
