Re: tire size 68 barracuda
[Re: AdamR]
#1484496
08/17/13 09:04 AM
08/17/13 09:04 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I am fitting a 275/50/15 currently with 3 5/8 backspace with the stock small bolt pattern offset. It needs the fenders rolled but just barely, if my car didn't sit so low rubbing would not be a problem.
Ages ago I ran a 265/50/14 I believe on a 3 3/4 back space 14x7 slotted mag. I also ran a 26x8.5 slick on a 14x8 rim.
The pic was 1997 or so, I miss those rims. I'm not sure what tire was on it then. Either a 245/60/14 or 265/50/14
68 Barracuda Formula S 340
[Re: Bad340fish]
#1484497
08/18/13 09:25 AM
08/18/13 09:25 AM
Posts: 7,978 Bethel Ct
AdamR
Bethel Ct
The stock wheel well will fit a pretty big tire. I had 325-50-15s on mine with the springs moved but stock wheel wells. There was another member with 295-65-15 or 315-60-15s in the stock wheel wells. Your issue will be finding big tires for 14" rims
Heres the 275-60-15
[Re: AdamR]
#1484498
08/18/13 09:28 AM
08/18/13 09:28 AM
AdamR
Bethel Ct
325-50-15
