tire size 68 barracuda #1484493
08/14/13 03:37 PM
08/14/13 03:37 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
what it a good FAT tire size for my 68 barracuda.
14 rim
Re: tire size 68 barracuda [Re: mcat4321] #1484494
08/14/13 03:59 PM
08/14/13 03:59 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I assume you are talking about the rears?
Small bolt pattern or large? Stock rear axles or new large bolt pattern or shortened original large bolt pattern axles?
On the rear 14x8 with 4.5 backspacing and 255/60/14 tire. If it's got original axles, might need 1/8" spacers or run 4.25 backspacing. If rear is all jacked up high, might be able to go higher.
Re: tire size 68 barracuda [Re: autoxcuda] #1484495
08/14/13 05:10 PM
08/14/13 05:10 PM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
You probably wont find anything bigger then a 245-60 for a 14" rim. They should be a 7" rim. Not sure you will find many 14X7" rims for the 4" bolt pattern.
Re: tire size 68 barracuda [Re: AdamR] #1484496
08/17/13 09:04 AM
08/17/13 09:04 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I am fitting a 275/50/15 currently with 3 5/8 backspace with the stock small bolt pattern offset. It needs the fenders rolled but just barely, if my car didn't sit so low rubbing would not be a problem.
Ages ago I ran a 265/50/14 I believe on a 3 3/4 back space 14x7 slotted mag. I also ran a 26x8.5 slick on a 14x8 rim.
The pic was 1997 or so, I miss those rims. I'm not sure what tire was on it then. Either a 245/60/14 or 265/50/14
68 Barracuda Formula S 340
Re: tire size 68 barracuda [Re: Bad340fish] #1484497
08/18/13 09:25 AM
08/18/13 09:25 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
The stock wheel well will fit a pretty big tire. I had 325-50-15s on mine with the springs moved but stock wheel wells. There was another member with 295-65-15 or 315-60-15s in the stock wheel wells. Your issue will be finding big tires for 14" rims
Heres the 275-60-15
Re: tire size 68 barracuda [Re: AdamR] #1484498
08/18/13 09:28 AM
08/18/13 09:28 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
325-50-15
Re: tire size 68 barracuda [Re: AdamR] #1484499
08/18/13 09:33 AM
08/18/13 09:33 AM
Bethel Ct
AdamR Offline
AdamR  Offline
Bethel Ct
315-60
