Superbird Clone HELP!!!!!!!!!! #1484317
08/14/13 10:41 AM
08/14/13 10:41 AM
Harrisville,PA
GRAYBO Offline OP
GRAYBO  Offline OP
Harrisville,PA
I'm building a father-son project superbird out of a 1970 Runner. I just got a pair of 1970 coronet fenders which I need to cut and fold the front bottom to match the "Bird" fender extensions. Does anyone have pics or info on the exact way to cut and fold these fenders. Also any tips on a SB clone would be greatly appreciated. Thanks in advance.
Re: Superbird Clone HELP!!!!!!!!!! [Re: GRAYBO] #1484318
08/14/13 11:27 AM
08/14/13 11:27 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
It's hard to get correct measurements from a picture,you'll get more and better information if you ask here,many of these guys have already done it !
http://www.dodgecharger.com/forum/index.php?PHPSESSID=hgi12l431pa1lmcl9h9p022n87&board=26.0
Re: Superbird Clone HELP!!!!!!!!!! [Re: GRAYBO] #1484319
08/14/13 06:32 PM
08/14/13 06:32 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you already have the Superbird lower valance corners, just take a tracing off those and apply it to the fender's lower edge, you only need 1" of extra material to create a lip that you roll over by whatever method you choose, hammer and dolly, or weld some steel stock to a pair of vise grips, basically making a large set of duckbill vise grips, or basically a mini metal break, so that you can bend over the lower 1" lip you've created by cutting off a portion on the lower dog leg of the fender, one thing to keep in mind, that most neglect until it's too late (often in paint at that time) is to assemble the nose onto the car, with the lower valance corners in place, you'll find that the outer upper corners of the nose project pass the tops of the Coronet's fender lines where they meet up with the nose, the factory leaded the top of the fender peaks to create a smooth transition between the top corner of the nose and the top fender peak/crease of the Coronet fender, you can either create this with lead, or body filler, depending on your skill sets, remember to remove the headlite structure spot welded to the fender, you don't need it, and Superbird fenders didn't have it, Superbirds also had no holes/screening cut for the fender scoops, unlike the Daytona's scoop set up
mike
Re: Superbird Clone HELP!!!!!!!!!! [Re: DAYCLONA] #1484320
08/15/13 11:11 AM
08/15/13 11:11 AM
Harrisville,PA
GRAYBO Offline OP
GRAYBO  Offline OP
Harrisville,PA
Thanks for the quick and informative response fellas. Much appreciated.
