Re: Six Pack air cleaners and filters
[Re: thehemikid]
#1484170
08/16/13 09:39 AM
08/16/13 09:39 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
The air filter itself is the hard part to get now. There is a bad repop available. Do a completed auction search on ebay for CA332V. That is an eye opener.
What's the problem with the re-pop? I was about ready to pull the trigger on one.
One of the issues is the size of the holes in the metal around the element are bigger than original.
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=7645764&Main=7627874
That would've been great, ... if the hole size was the only problem.
Make sure there's a good return policy.
Like said,not the only problem !
[Re: 62maxwgn]
#1484171
08/16/13 10:07 AM
08/16/13 10:07 AM
Posts: 1,318 Ohio
jlatessa
Ohio
As far as positioning the decal, it looks like the only place it fits is to the rear of the cover, behind the formed peak. Joe
P.S. I now have available a 3" high K&N oval filter, (un-used) for someone with a hood scoop or otherwise usable clearance.
New they are about $85, I will sell for $45, plus shipping.
[Re: 69x]
#1484172
08/16/13 10:47 AM
08/16/13 10:47 AM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
Ok, I have a question, who and why started calling these "Six Pack" Filters ?
This is the same filter that you would use with any Air Grabber or RamCharger 383 or 440 car, and also any Hemi car with fresh air, is this correct ? I think so.
[Re: jlatessa]
#1484173
08/16/13 11:10 AM
08/16/13 11:10 AM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
PM sent
[Re: JohnRR]
#1484174
08/16/13 11:13 AM
08/16/13 11:13 AM
69x
ok, so they are the same as I thought, I see you are one of those helpful people on this site...........very nice
[Re: 69x]
#1484177
08/16/13 04:42 PM
08/16/13 04:42 PM
JohnRR
U.S.S.A.
Glad to be of service , your question was a little silly , I doubt anyone here knows who started calling it a SIX PACK FILTEr ... if anything it should be called a HEMI filter since 6pks didn't come out till after febuary of 69 , hemis first day of production ... ...
Do you really think they would get as much $$$ if they were just called Ramcharger/Air Grabber filters ???
[Re: JohnRR]
#1484178
08/16/13 06:08 PM
08/16/13 06:08 PM
69x
I did not know that you were the judge and jury whether a question is silly or not. Whatever
[Re: 69x]
#1484180
08/17/13 12:28 AM
08/17/13 12:28 AM
JohnRR
U.S.S.A.
Now you do ...
[Re: LimeliteAero]
#1484182
08/18/13 11:11 AM
08/18/13 11:11 AM
Posts: 21,449 It's a dry heat
gtx6970
It's a dry heat
weren't there round hemi and ram-charger air filters...only oval six-pacs?
Yes,,, and no,
All Hemis with the air grabber hood were oval air filters
383 and 440 engines and single 4 barrel with the air grabber 1970 thru 1972 were round elements , shown
[Re: jlatessa]
#1484184
08/18/13 02:22 PM
08/18/13 02:22 PM
KillerBee
N.E. Ohio
Man those current repop oval filters look TERRIBLE! I think I'm going to put my new correct repop oval filters back away in case I need them. Would it be possible to gently pull apart a used correct oval filter? You could remove the old dirty pleats and install new ones then re-assemble it? Jlatesse hooked me up with a deal on a 3" tall K&N oval filter which fits perfectly under the T/A hood on my Challenger. Thanks Joe
[Re: gtx6970]
#1484185
08/18/13 02:24 PM
08/18/13 02:24 PM
Posts: 6,585 SE Pa.
LimeliteAero
SE Pa.
Yes,,, and no,
I knew the answer Bill, I was just making a point that six-pacs were the only engine that was equipped with the ovals.
[Re: LimeliteAero]
#1484186
08/18/13 04:16 PM
08/18/13 04:16 PM
Posts: 4,361 swamps of florida
beepsalot
swamps of florida
all six barrel motors and fresh air hemis, ,70 B bodies up hemi cars. the fram number for the 14 round is CA305
Just Follow Me Down the Street, You'll Know i'm Up to No Good...
[Re: LimeliteAero]
#1484188
08/19/13 09:44 AM
08/19/13 09:44 AM
JohnRR
U.S.S.A.
If you want to get nit picky then yes there are.
But can you answer the man's question ? He has a rope and a tree branch with nothing to do ...
