nitrous question #1483988
08/13/13 07:50 PM
08/13/13 07:50 PM
california
hornetnut Offline OP
california
i have an 11.1 440, eddy heads, ultradyne 582 lift 282 @ 050, 850 dp holley, 4.11 gears 2500 verter.. what do you think ill pick up with a 100 shot of nitrous?
Re: nitrous question [Re: hornetnut] #1483989
08/13/13 07:57 PM
08/13/13 07:57 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
3th's
Re: nitrous question [Re: a493demon] #1483990
08/13/13 08:46 PM
08/13/13 08:46 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
My Demon with a 15-1 360 and Hughes stage 2 ported stock heads and Hughes solid cam around .615 lift went from 7.20 to 6.47 in the 1/8 with severe traction problems. Picked up 11 mph. Had 47 nos/53 fuel jets in a cheater plate, supposed to have been 100 shot according to N.O.S.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: nitrous question [Re: D-50] #1483991
08/13/13 09:24 PM
08/13/13 09:24 PM
a493demon Offline
a493demon  Offline
is that jetting backward's ?
Re: nitrous question [Re: a493demon] #1483992
08/13/13 10:05 PM
08/13/13 10:05 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
No, that is what I used.
Re: nitrous question [Re: D-50] #1483993
08/13/13 11:02 PM
08/13/13 11:02 PM
a493demon Offline
a493demon  Offline
every thing I have read always has a bigger NOS jet then the fuel jet.
Re: nitrous question [Re: a493demon] #1483994
08/13/13 11:16 PM
08/13/13 11:16 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I just looked on my instructions and it has 47 n2o jet and 53 fuel jet.I ran mine that way for about 8 years and never had any problems. I would pick up close to 8 tenths in the 1/8.
Re: nitrous question [Re: D-50] #1483995
08/13/13 11:28 PM
08/13/13 11:28 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
NOS always jets a little fat. (SAFE!)
I agree 3-4 tenths
Re: nitrous question [Re: D-50] #1483996
08/13/13 11:48 PM
08/13/13 11:48 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Insructions are WAY off for a decent jet package. That's not even a little fat, that's a LOT of FAT!!! Monte updated a lot of the NOS tunes and that looks like an old one. The 100 shot set up I use to start is 47N/40F. I run a minimum of 7 steps smaller on fuel than n2o to start and step on it from there. Some guys like Monte, IIRC, have stated to run 10 smaller.
Sniper/powershot/cheater, jet them all the same and the fuel jet should not be larger than the n2o jet. That's what Monte told me.
You guys are beating the ring lands to death with those fat tune ups.
There is a guy on another site using a super powershot IIRC, ran the stock 150 NOS jetting, 55/61 picked up .7-.8. Changed it to square 55/55, pulled timing, it's picked up close to 1.4 seconds and it's still fat! 13.3 to 11.91 and there likely still another 3-4 tenths in it.
Re: nitrous question [Re: RobX4406] #1483997
08/13/13 11:55 PM
08/13/13 11:55 PM
a493demon Offline
a493demon  Offline
I think right now I have a 14 spread .
NOS bigger jet.
Re: nitrous question [Re: a493demon] #1483998
08/14/13 09:41 AM
08/14/13 09:41 AM
an8sec70cuda Offline
The old tuneups used a bigger fuel jet than the nitrous. The new tuneups are squared. Much better, but still fat.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: nitrous question [Re: a493demon] #1483999
08/14/13 12:24 PM
08/14/13 12:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
3th's
in the 8th? I'd think a 100 shot would be good for at least 5-7 tenths in the 1/4.
Coming soon!!!!
Re: nitrous question [Re: Biginchmopar] #1484000
08/14/13 12:39 PM
08/14/13 12:39 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
The more modern theory is that Fat is not safe....Fat kills ringlands.
Re: nitrous question [Re: Quicksilver440] #1484001
08/14/13 01:29 PM
08/14/13 01:29 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
i just hit my junk with a "100" shot. I reversed the recommended jetting to 53N/47F and the plugs looked pretty good, stayed conservative with timing.
How tall of a tire? will you run out of revs at the stripe?
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: nitrous question [Re: OUTLAWD] #1484002
08/14/13 04:42 PM
08/14/13 04:42 PM
california
california
it is 1/4 mile and i have 26x10 slicks.. im hoping for 1/2 sec drop.. i shift normally at 5500, and cross the stripe about the same..
Re: nitrous question [Re: Quicksilver440] #1484003
08/14/13 04:43 PM
08/14/13 04:43 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
IMO, its not "theory", its fact.
Go to one of Monte's classes. He explains it in very good detail.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: nitrous question [Re: hornetnut] #1484004
08/14/13 04:56 PM
08/14/13 04:56 PM
RobX4406 Offline
RobX4406  Offline
What's it run now?
A 100 shot on a 13 second car will pick up ~1+ seconds, same shot on an 11.00 car, not so much.
Re: nitrous question [Re: RobX4406] #1484005
08/14/13 05:38 PM
08/14/13 05:38 PM
california
california
11.60
Re: nitrous question [Re: hornetnut] #1484006
08/14/13 06:18 PM
08/14/13 06:18 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Not sure but I think you'll pick up more with a smaller cam or a lot more converter (5000+). What are you running for heads, intake, and exhaust?
Re: nitrous question [Re: GTX MATT] #1484007
08/14/13 06:50 PM
08/14/13 06:50 PM
california
california
i was told this verter was supposed to stall over 3500, but i can only get 2500 out of it, eddy perf rpm heads, perf rpm intake, long tube headers and 3 in exhaust
