FBO Systems Ignition: good choice? #1483545
08/12/13 09:38 PM
08/12/13 09:38 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
HRR688DWR Full Conversion http://4secondsflat.com/Ignition.html
for $429.00 includes ECU, dist and coil
Seems like a good deal and I like the fact that it will install easily to the stock wiring harness and will replace the ECU. without the bulky and hassle to install MSD 6.
Re: FBO Systems Ignition: good choice? [Re: domingo] #1483546
08/12/13 10:01 PM
08/12/13 10:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I look around the track and see what everyone else
is running... I might be borrowing parts .. and all
those people cant be wrong... I bought different stuff
over the years and I'm running MSD
Re: FBO Systems Ignition: good choice? [Re: MR_P_BODY] #1483547
08/13/13 12:31 AM
08/13/13 12:31 AM
I use to have the part number of the ECU that Don buys and repackages for his kits, I don't use them either Mopar or MSD all the way
Re: FBO Systems Ignition: good choice? [Re: domingo] #1483548
08/13/13 04:01 AM
08/13/13 04:01 AM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
ill go with the complete MSD ignition setup then....
