Re: 2001 Ram 3500 360 misfire
[Re: UCUDANT]
#1483272
08/12/13 09:46 PM
08/12/13 09:46 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I think at some point Chrysler issued a TSB about plug wire routing and crossfire on Magnum engines...
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#1483273
08/13/13 08:03 AM
08/13/13 08:03 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
the odd looking wire re-route to solve ignition wire crossfore, particularly cylinders 5 and 7, is here: http://dodgeram.info/tsb/1998/18-48-98/18-48-98.htmalong with checking the o-ring seals of the injectors, check the catch screens at the top of the injectors, particularly cylinders 7 and 8 at the back which are "first in line" to receive any gunk coming from the fuel line. cylinders 7 and 8 deserve a bit of extra attention: the plenum gasket usually blows inside the intake back near the inner inlets to 7 and 8 the headgasket usually blows at 7 or 8 these two cylinders seem to run leaner and hotter, perhaps because the design of the exhaust manifold gives these two cylinders less backpressure and therefore less internal EGR, more fresh air in the cylinder intake charge it may also be there is not enough coolant flow to those back cylinders. When Evans Cooling tested their NPG coolant in Police service 5.2v8 Magnums in MI years ago, their research report said they had to remove the heads and enlarge the coolant hole in the head gasket for the rear two cylinders. doing an individual cylinder RPM drop comparison power balance test on the might show the weak ones
[Re: Challenger 1]
#1483275
08/13/13 09:21 AM
08/13/13 09:21 AM
Posts: 8,162 USA
360view
USA
How does a cracked head cause a misfire?
I guess if there is a really bad crack running from valve seat to valve seat across the ridge, so much gas would leak past the non-sealing valves, that compression would really low, and there could be a missfire even though air, fuel and spark were at spec
Factory Magnum cylinder head cracks are common across the thin ridge of the heart shaped combustion chamber. These cracks are usually tight and shallow, with the majority not penetrating to the coolant passages.
A "dynamic compression test" with a noid light connected in that cylinder instead of the fuel injector, would spot low compression with the added benefit of spotting possible valve, spring, and rocker arm problems.
http://www.misterfixit.com/dyncompr.htm
Magnum rocker arms have been known to go bad, where the push rod meets its ball socket.
[Re: UCUDANT]
#1483281
08/17/13 12:32 PM
08/17/13 12:32 PM
Posts: 2,177 ill
dennismopar73
ill
Computers get the blame for a lot of issue that may not be a computer issue? Just saying. Most pcms will not keep throwing the same codes, so lead to believe the issue is ,(wiring issues) or mechanical controled! Misfire could comein the form of injector, easy to see , just remove one from another cyl and put in that hole, if it stays on 6, then not the inj! move to next item switch wires to the plug, etc, change plug the same way , time consuming, but xcheaper than throwing money on items not needed!!
