Shrowd fasteners ? Sealing #148255
11/10/08 01:19 PM
11/10/08 01:19 PM
North Riverside IL & Lowell IN
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I was changing fluids this weekend and I don't like the way my shroud is bolted to the rad. I'm running a stock shroud to a stock style rad. What kinds of fasteners are used to hold the radiator to the shroud?
Do any of you use foam tape of something else to seal your shroud to the radiator?
Re: Shrowd fasteners ? Sealing [Re: GTXKen] #148256
11/10/08 02:52 PM
11/10/08 02:52 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
On a 1970 B-body I assume ?
22" radiators use 4 of -
http://amhightechauto.com/images/parts/875.jpg
26" radiators use -
http://amhightechauto.com/images/parts/886526.jpg
Re: Shrowd fasteners ? Sealing [Re: gtx6970] #148257
11/10/08 03:41 PM
11/10/08 03:41 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Thanks Bill, yes it's a 70 with a 26" radiator.
My old radiator had bolts threaded directly into the sheet metal, I suspected that was incorrect.
