Trans temperature sensor #1482326
08/10/13 12:32 PM
08/10/13 12:32 PM
STL
cdstl Offline OP
cdstl  Offline OP
STL
My son took our '96 Dakota 318 4x4 to Auto Zone to get a code for the check engine light. Besides the misfire on #1 he got a transmission temperature sensor code.
How much of a pain is it to replace the sensor. Dropping the pan requires lifting the engine since it hits on something under there. It's been 10 years since I was going to change the filter and ended up taking it in.
Trans was rebuilt two years ago and has maybe 5000 on it.
The misfire is probably related to one of the boys running out of gas since the thing runs great. Probably could use an injector cleaner.
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Trans temperature sensor [Re: cdstl] #1482327
08/10/13 12:45 PM
08/10/13 12:45 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Clear the codes and drive it normally to see if it was a fluke.
