Valve length question #1482074
08/09/13 12:50 PM
08/09/13 12:50 PM
CO
N
Nitrojunkee Offline OP
N
CO
I'm using a pair of Edelbrock RPM heads that are being stuffed with 2.19" intake and the standard 1.81" exhaust valves. Going with a solid roller blower grind from Bullet. I know the stem diameter on the RPM's are 11/32. But my question is, will the stock valve length work with a .600 lift cam? Or will I have to go with a longer valve?
Re: Valve length question [Re: Nitrojunkee] #1482075
08/09/13 12:59 PM
08/09/13 12:59 PM
AndyF Offline
AndyF  Offline
RPM heads should be good past .600 lift. You should be able to get about 1.80 or 1.85 installed height on the valve spring which should give you enough for more than .600 lift.
Re: Valve length question [Re: Nitrojunkee] #1482076
08/09/13 01:11 PM
08/09/13 01:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Pettis put 2.19 valves in my home ported rpm`s and everything`s great so far w/a .680-.660 Isky solid roller however the installed height leaves a bit to be desired.
Re: Valve length question [Re: AndyF] #1482077
08/09/13 01:19 PM
08/09/13 01:19 PM
CO
N
N
CO
Awesome, thanks for the info! I was thinking along those lines, but wasn't sure.
Re: Valve length question [Re: Thumperdart] #1482078
08/09/13 01:34 PM
08/09/13 01:34 PM
CO
N
N
CO
Nice! I'm actually doing some home bowl work, and mild porting myself as well. I'd like to see 300-310cfm @ .600 lift, with the 2.19's and my bowl work/porting. We'll see what the flow bench comes back with lol.
Re: Valve length question [Re: Nitrojunkee] #1482079
08/09/13 02:45 PM
08/09/13 02:45 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not sure what mine flow and don`t really care but the bigger valve along w/good bowl work and valve job should be a good improvement........
Re: Valve length question [Re: Thumperdart] #1482080
08/09/13 03:36 PM
08/09/13 03:36 PM
CO
N
N
CO
By the way, who's valves did you go with? Are you using titanium retainers?
Re: Valve length question [Re: Nitrojunkee] #1482081
08/09/13 03:47 PM
08/09/13 03:47 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I think they were SI valves but not sure honestly and my retainers are 13+ year old TI from Isky.
Re: Valve length question [Re: Nitrojunkee] #1482082
08/09/13 10:23 PM
08/09/13 10:23 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If you really want to maxamize the intake port do away w/as much p-rod pinch as you can or sleeve it so you know how far you can go.........Mine are very thin but if I did it again I`d do as suggested w/the sleeves.
Re: Valve length question [Re: Thumperdart] #1482083
08/09/13 10:43 PM
08/09/13 10:43 PM
CO
N
N
CO
Gotcha. Thanks for all the info!
Re: Valve length question [Re: Nitrojunkee] #1482084
08/09/13 10:46 PM
08/09/13 10:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Tubing
http://ksmetals.com/RetailLocations.html
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Valve length question [Re: pittsburghracer] #1482085
08/09/13 10:58 PM
08/09/13 10:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Tubing
That be it............off to go beat on my this weekend so have fun.
