Do RPM's hang with aftermarket efi? #1481920
08/09/13 09:32 AM
08/09/13 09:32 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys, just wondering if any of you that run some type of aftermarket efi notice hanging rpm's when revving the car up?
I only have experience with my 2001 ram, and i hate that coasting, hanging engine speed when letting off the throttle. Just wondering if I retrofit efi onto my old car, will it do the same thing?
Thanks for any info.
Re: Do RPM's hang with aftermarket efi? [Re: kielbasa] #1481921
08/09/13 10:11 AM
08/09/13 10:11 AM
Lakewood, Colorado
herkamer Offline
herkamer  Offline
Lakewood, Colorado
Doesn't happen with my Megasquirt.
Matt
69 Dart Swinger 340
83 W350, Megasquirted with 46RH
Old news: 72 Demon street/race mobile
Latest: 70 Duster backhalf car
and even more
Re: Do RPM's hang with aftermarket efi? [Re: kielbasa] #1481922
08/09/13 11:02 AM
08/09/13 11:02 AM
Andrewh Offline
Andrewh  Offline
I would bet it is more a bad tps in your ram then the efi setup.
I already had to replace the one off the engine from a 2000 durango.
it would hold open at 2k rpm even with my foot off the pedal.
had to shut off the car and restart to get it to reset till I replaced it.
Re: Do RPM's hang with aftermarket efi? [Re: kielbasa] #1481923
08/09/13 01:48 PM
08/09/13 01:48 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
No. The "hanging" has nothing to do with aftermarket EFI.
Most systems offer a feature which holds the IAC open on a quick throttle release just so the engine doesn't stumble, but this is an adjustable feature which can be turned totally off. A bad TPS can do this too.
Re: Do RPM's hang with aftermarket efi? [Re: Mopar_Rich] #1481924
08/09/13 07:12 PM
08/09/13 07:12 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The "hang" is an emmisions thing on most OEM stuff. As Rich said it can be set from zero to whatever with the IAC on aftermarket EFI.
Kevin
Re: Do RPM's hang with aftermarket efi? [Re: Twostick] #1481925
08/09/13 11:35 PM
08/09/13 11:35 PM
IN
ahy Offline
ahy  Offline
IN
I've got the FAST system and I adjusted mine so it doesn't stumble or stall but is not noticeable in normal driving.
Re: Do RPM's hang with aftermarket efi? [Re: ahy] #1481926
08/13/13 12:21 PM
08/13/13 12:21 PM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
Can anything be done about it for fac efi? Im running a mag w/factory efi in my 48 and love everything about it except the way throttle "hangs" forever it seems.
48 plymouth 2 door sedan street rod
65 meyers manx dune buggy
66 coronet 500 (resto project)
77 w200 m880
02 dakota
Re: Do RPM's hang with aftermarket efi? [Re: 66cnet500] #1481927
08/13/13 12:32 PM
08/13/13 12:32 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Yes, this can be programmed out, but you have to find someone who has the software and the expertise to do it. Find out who the ECU manufacturer is, many were AEM. If its an AEM unit you should be able to find someone close to you.
Re: Do RPM's hang with aftermarket efi? [Re: Mopar_Rich] #1481928
08/13/13 01:02 PM
08/13/13 01:02 PM
newark oh.
66cnet500 Offline
66cnet500  Offline
newark oh.
Saweet, thanks bro deff gonna look into it.
77 w200 m880
02 dakota
