cranking compression question #1481768
08/08/13 09:50 PM
08/08/13 09:50 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
On a low comp 440(75 model 8.2-1 advertised)what would be a good cranking compression number?
The motor was cold and the cylinders dry.
Re: cranking compression question [Re: gch] #1481769
08/08/13 10:07 PM
08/08/13 10:07 PM
I'd be comfortable with 140 give or take 10 either way & happy with 150 or more. Critical is that there are no low ones
Re: cranking compression question [Re: RapidRobert] #1481770
08/08/13 10:55 PM
08/08/13 10:55 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
The cylinders are all within 10 psi but the numbers are a LOT lower.I was thinking 120 at best with that low of a compression but all are between 80-90.
Re: cranking compression question [Re: gch] #1481771
08/08/13 11:03 PM
08/08/13 11:03 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I was thinking around 100ish. Have the head gaskets been changed anytime that you know of?
Re: cranking compression question [Re: gch] #1481772
08/08/13 11:41 PM
08/08/13 11:41 PM
It's in need of a rebuild
Re: cranking compression question [Re: gch] #1481773
08/08/13 11:41 PM
08/08/13 11:41 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
80 to 90???? Ouch!!!! it will run but will have its tail between its legs,
Re: cranking compression question [Re: gch] #1481774
08/09/13 12:31 AM
08/09/13 12:31 AM
AndyF Offline
AndyF  Offline
I checked the cranking compression on my stroker motor the other day and it was 235 psi. And that is with a 280 at 0.050 camshaft. I can barely turn the engine over with a cheater bar.
Re: cranking compression question [Re: gch] #1481775
08/09/13 12:56 AM
08/09/13 12:56 AM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline
ek3  Offline
E
100 lbs. will work fine. you would be surprised what just a good valve job or a new timing chain would do. warm it up, pull all the plugs out, and spin it over 3-4 times to test. when you warm it up , run a little marvel mystery oil in it also then re-check it. a good fresh 440 with 8 -1 compression making 130-40 lbs. would run fine. if you are looking for real power , 9:5:1 or better and 175 + is a good starting point. if the engine has set up for a long time, while running it, pour a little diesel fuel [ about a quart untill gone] in the carb when it is hot and revved up some . this will free the rings / valves up .
Re: cranking compression question [Re: AndyF] #1481776
08/09/13 01:27 AM
08/09/13 01:27 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Holy crap! Thats a RACE fuel engine for sure!
I was at 190 in my 440/493. 10.7 static with the MP '509 cam.
Re: cranking compression question [Re: Kern Dog] #1481777
08/09/13 09:30 AM
08/09/13 09:30 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Motor/car has been sitting for 10 plus years but runs surprisingly smooth.Still has the cat converter lol. I was hoping for a little higher number so I could justify throwing some spare performance parts on it and making a rat rod/beater for fun.Pulling the heads is more $$$ than I want to put in to it.
I drove it home on 13 year old tires and then found out the idler arm was about to fall off of it.lol
Re: cranking compression question [Re: gch] #1481778
08/09/13 09:36 AM
08/09/13 09:36 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Tell you what - It will run fine. All the cylinders are even showing me that it has pretty equal wear pattern. Doing a valve job (unless you have a valve leak) will do nothing for you. an even test like you have does not represent a leaky valve. A cylinder with a leaky valve most generally will have a pretty noticeable compression drop from the rest. Not an even reading like you have.
Re: cranking compression question [Re: MoparforLife] #1481779
08/09/13 10:01 AM
08/09/13 10:01 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Just a thought, are you cranking with the carb at WOT?
Joe
Re: cranking compression question [Re: jlatessa] #1481780
08/09/13 10:27 AM
08/09/13 10:27 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I had my mechanic do it because I am lazy. I will have to ask him.
Re: cranking compression question [Re: gch] #1481781
08/09/13 11:15 AM
08/09/13 11:15 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I have never understood it
but
100 psi minimum
is the cranking compression listed
in the official
Dodge Ram 1995
Field Service Manual
specs page for the
488 ci/8L iron V10
which is a spec of
8.4 to 1 static compression
and has a quite modest duration camshaft.
Re: cranking compression question [Re: 360view] #1481782
08/09/13 11:25 AM
08/09/13 11:25 AM
USA
3
360view Offline
360view  Offline
3
USA
167 psi
on a warm engine
with a shot of oil in each cylinder
throttle bores propped fully open
starter turning crank at 300 rpm
75 degrees F
700 feet above sea level
is what the
PerformanceTrends Engine Analyzer 3.2
computer software estimates
should be on the fourth stroke of the piston
when the camshaft specs for a
1995 488 iron V10 are entered
Re: cranking compression question [Re: 360view] #1481783
08/09/13 11:35 AM
08/09/13 11:35 AM
USA
3
360view Offline
360view  Offline
3
USA
178 psi
is what the
EA 3.2 estimates for the
1969 Mopar 440 V8
This a an example engine that comes with the program.
Specs are filled in by the author of the software
Kevin Gerten, an ex-Ford engine development engineer.
Static compression is 10 to 1
Intake Valve timing:
centerline 113 degrees
duration at 0.050. 214
open at 0.050 -6 degree btdc
close 40 degrees abdc
gross lift 0.447 inches
SAE conditions HP
on 93 octane AKI gasoline
309 horsepower at 4200 rpm
410 ft-lbs at 3200 rpm
0.497 lbm/hp-hr BSFC at 2200 rpm
Re: cranking compression question [Re: 360view] #1481784
08/09/13 12:06 PM
08/09/13 12:06 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I don't think the o/p stated how many hits of each cylinder were utilized for his findings. I go about 4 cycles which gets you close enough. Some folks have said they just bring it around once and that won't work as the first spin has to fill the gauge-hose etc.
Re: cranking compression question [Re: buildanother] #1481785
08/09/13 12:49 PM
08/09/13 12:49 PM
P
Paul_Fancsali Offline
P
That engine is a 7.5 comp at best 90 psi is plenty after not being run and sitting Drive it some add some sea foam and bet it will be over 100 Those engines new barely cranked 125 psi If they are all even it alone change the timing chain get a cam that will help it out Comp 260 series comes to mind
Re: cranking compression question [Re: Kern Dog] #1481786
08/09/13 04:45 PM
08/09/13 04:45 PM
California
mickm Offline
mickm  Offline
California
the new engine is 210 on every cylinder, and runs fine on 91. but i guess 25 more is a lot. same thing for me, tying to turn it over with a breaker bar is an exercise in upper body strength.
Re: cranking compression question [Re: mickm] #1481787
08/09/13 06:57 PM
08/09/13 06:57 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
205psi on 93 pump, they run so nice with hi cranking pressure !!!
