Do torsion bars wear out after time? #1481555
08/08/13 03:01 PM
08/08/13 03:01 PM
Penna
70satelliteguy Offline OP
Penna
I have the Drag racing diameter size torsion bars on my 70 B body now for about 6 years ,probably 500+ passes on them. The car is heavy(3600 lbs.) .I am not having any problems that I know of but was just wondering if this is a part that should be replaced at some time.
Thanks Mike
Re: Do torsion bars wear out after time? [Re: 70satelliteguy] #1481556
08/08/13 03:52 PM
08/08/13 03:52 PM
AndyF Offline
AndyF  Offline
Springs only wear out if they are overstressed. If you stay below the fatigue life on spring steel then the life is infinite.
Having said that, drag bars can be overstressed in a 3600 lb car, especially if you have a lot of front end travel. So yeah, I'd replace them every 5 years or so if it was my car.
Re: Do torsion bars wear out after time? [Re: 70satelliteguy] #1481557
08/08/13 04:23 PM
08/08/13 04:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
yes... a spring is a spring...if it jounces a bit harder
than normal it takes its toll
Re: Do torsion bars wear out after time? [Re: 70satelliteguy] #1481558
08/08/13 04:52 PM
08/08/13 04:52 PM
Penna
Penna
Thanks for the reply's The car does probably stress the bars some with 1.30 60 fts. and wheelstands. Guess I will replace them this winter just to be sure.
Mike
Re: Do torsion bars wear out after time? [Re: 70satelliteguy] #1481559
08/08/13 05:51 PM
08/08/13 05:51 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I would think on a Drag car the weaker the better!Was that not the reason we used to replace the torsion bars off all the V8 B body cars with the torsion bars of the 6 cylinder cars,weaker bars?
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Do torsion bars wear out after time? [Re: AndyF] #1481560
08/08/13 09:24 PM
08/08/13 09:24 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Since on Mopars, they are inherently limited by design, as to how far they can be maximum loaded/twisted, the difference that matters here is how much preload/twist is dialed in for static ride height, and then adding maximum travel thru bumps/wheelstands, etc, which then approaches the over stressed area. I am surprised there is not a value published/known for maximum degrees of twist allowed for each bar. And I always heard as a rough idea loading typical steel to approx 70% tensile strength gives about 6-10,000,000 cycles of useful life. As you start approaching 100% it starts dropping faster, just to put a number on "infinite".
Re: Do torsion bars wear out after time? [Re: jcc] #1481561
08/08/13 09:50 PM
08/08/13 09:50 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
All I can say is I have owned 60's and 70's Mopars since 1974 and I have never broken or wore out a torsion bar. I have heard of some people having one break but I have not seen this. In fact the bars in my 63 are still the original stock 383 torsion bars. Ron
Re: Do torsion bars wear out after time? [Re: 383man] #1481562
08/08/13 11:29 PM
08/08/13 11:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you running stock bars... stock bars will last for
damn near ever if your not pulling wheelies or run on
bad roads... when you jounce them more than the normal
they start to sag.... I worked on the F-body transvers
suspension project and even during the preload I had
4 or 5 bars blow.. when they did blow(they were under
a shield) it was like a bomb going off.. and sent
a razor sharp chunk flying but was contained in my
fixture..
when ever it did blow.. most of the building came to
see what happened
Re: Do torsion bars wear out after time? [Re: MR_P_BODY] #1481563
08/08/13 11:51 PM
08/08/13 11:51 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
The drivers front torsion bar in my (heavy) 440 six pack Super Bee is sagging as it is cranked all the way up while the passenger side adjusting bolt is only half way in...
Original .920 bars.
I am ordering 2 new ones.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Do torsion bars wear out after time? [Re: 383man] #1481564
08/09/13 12:01 AM
08/09/13 12:01 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ron I started running Mopars in 65.I only had one bar snap/It was my 67 Plymouth Fury.Parked it and came out the next day to go to work.The one side was snapped.My old man started driving them in the 50s.Thats the only one Ive ever seen snapped.I had one of the trans verse one at the shop that snapped.That was at least 30 years ago.Rocky
Chrysler Firepower
Re: Do torsion bars wear out after time? [Re: therocks] #1481565
08/09/13 09:35 AM
08/09/13 09:35 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
The only vehicle I had that broke a torsion bar was my
'78 B body. I feel the reason it broke is because the ends of that bar were rusted into the sockets but maybe I am off base.
I had just ran an errand, got out of the car and BLAM! Like a gun going off. Instant low rider, but only on one side
Rich H.
Esse Quam Videri
Re: Do torsion bars wear out after time? [Re: ZIPPY] #1481566
08/09/13 10:56 AM
08/09/13 10:56 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I had a 78 M body that only had about 70k miles on it when the T bar broke , the car had that many miles on it when it about 25 years old , nice and not rusty by any means, my brother was driving it , hit a pothole and BANG !
Re: Do torsion bars wear out after time? [Re: JohnRR] #1481567
08/09/13 11:52 AM
08/09/13 11:52 AM
Penna
Penna
They are not that expensive. I am still planning on new bars over the winter.
Mike
Re: Do torsion bars wear out after time? [Re: ZIPPY] #1481568
08/09/13 12:49 PM
08/09/13 12:49 PM
AndyF Offline
AndyF  Offline
Both torsion bars in the Duster drag car that I bought a few years ago were twisted. The bars had been installed on the wrong side and I had to beat on them pretty hard to remove them. When I got them out and inspected them I could see that they were both twisted. So something happened along the way.
Re: Do torsion bars wear out after time? [Re: AndyF] #1481569
08/09/13 01:48 PM
08/09/13 01:48 PM
STL ,MO
Handygun Offline
Handygun  Offline
STL ,MO
Broke a bar in a 69 Coro once. Parked at the pump while I was in paying. 318 car, early eighties.
Re: Do torsion bars wear out after time? [Re: MR_P_BODY] #1481570
08/09/13 02:00 PM
08/09/13 02:00 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
fixture..
see what happened
Yes I am running the stock bars. As like always on my cars they are adjusted where I like them with plenty of adjustment left. Like I said I have heard of them breaking but I have never had one break on me and never even seen one break but I know they can break. And I sure dont go around pulling wheelies everyday. Heck I am glad to get 6 inches or more off the ground when it hooks. I never have cared for the F-body (Aspen & Volare) torsion bar setup. Ron
Re: Do torsion bars wear out after time? [Re: therocks] #1481571
08/09/13 02:07 PM
08/09/13 02:07 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I guess I have been lucky so far. I wondered how the bars would act if put in on the wrong side since they would twist the oppisite way ? Now watch my luck I will have a bar break this week on me. Ron
Re: Do torsion bars wear out after time? [Re: 383man] #1481572
08/09/13 02:10 PM
08/09/13 02:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A lot of hot rodders love the F & M body front suspension..
with a few turns you can have it way up or down low
plus its a self contained unit
Re: Do torsion bars wear out after time? [Re: 70satelliteguy] #1481573
08/09/13 02:17 PM
08/09/13 02:17 PM
Indiana
MFR426 Offline
MFR426  Offline
Indiana
I know I am aging myself, but back in 1957 when my parents bought their new 57 Savoy, after about 6 months we had one break. Since mom worked at the dealer we found out that they had defective ones that the metal was not up to specs. This was corrected and you didn't hear of them breaking until the Aspen/Volare days which I can attest too as I used to have the broken one under my house and I didn't move it so wonder if it is still there since I moved 10 years ago! Ha! Metal is metal and will have a stress point at some time, but when that will be is dependent on amount of stress and number of movements and each one is probably different. We have spares just in case!
Re: Do torsion bars wear out after time? [Re: 383man] #1481574
08/09/13 04:52 PM
08/09/13 04:52 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My old Duster had a torsion bar "wear out". Found it after unloading it at the MATS a number of years ago. Had to use a floor jack to get it out of the trailer and went to the swap area to buy replacements. Curiously enough it had the race/6 torsion bars in it, only replacements I could find were 340 bars and car made its quickest runs ever in Vegas that weekend.
