I suspect the trunk gasket is leaking due to\
1 previous body damage preventing the seal all the way across the back
2. wrong trunk gasket
3. trunk gasket installed wrong.
When setting up the gaskets we use a sheet of paper. IE: close the lid with the paper between the lid and gasket, then check for resistance when trying to remove the paper. pay particular attention the rear sealing area as that is usually where the exhaust gets in. Same trick works on windows and doors too
Another messier way is to coat the gasket with a thin layer of Vaseline close the trunk, then reopen and look for areas that it was not transferred to
