833 main shaft ??? #1481357
08/08/13 12:34 AM
08/08/13 12:34 AM
Outside
thedriver Offline OP
Outside
Need new output shaft in my 833. Can I use one from an od trans, provided its the same length? And transfer my standard gears on to the od shaft?
1973 challenger
Dana. 4 speed. Low deck.
Re: 833 main shaft ??? [Re: thedriver] #1481358
08/08/13 01:14 AM
08/08/13 01:14 AM
Lawton, MI
Headhunter22 Offline
Lawton, MI
I am no expert but maybe take a look at Brewers page on mainshafts. I think the answer is no.
http://www.brewersperformance.com/products.asp?cat=18
Re: 833 main shaft ??? [Re: Headhunter22] #1481359
08/08/13 01:41 AM
08/08/13 01:41 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you are correct , NO you can't use the mainshaft from an OD trans in a non OD trans , the journal that 3rd rides on is smaller on the OD trans
Re: 833 main shaft ??? [Re: JohnRR] #1481360
08/08/13 01:43 AM
08/08/13 01:43 AM
Outside
Outside
Perfect.
1973 challenger
