My car doesn't want to run when its hot #1481169
08/07/13 08:04 PM
08/07/13 08:04 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
This is an update from a previous thread. I have a stock rebuilt 340 with electronic ignition and a harms built Thermoquad. The car starts up and runs mint for about 35-40 minutes after that it does not want to idle. I had it out yesterday and at the thirty minute mark I was in a parking lot and the car was running mint. I was able to stop and go into reverse and start and stop several times with no issues. 5 minutes later on my way home the idle starting getting rough. I limped to my driveway and tried checking a few things. Choke was wide open at this point. I covered the choke with my hand and the car wanted to stall out. (no vacuum leak??). I tried adjusting the mixtures screws a little and it seemed as though they were already in the best spot. The temp gauge is showing a normal operating temp but after fiddling with those few things the car now does not want to idle at all. It will start right back up but seemed as though it was now loading up. When I give it gas it spudders and wants to bog out, some smoke is present in the exhaust and when it does stall, I can see a mist of gas pop up through carb. It did back fire at one point and blew of one of the vacuum caps on my brake booster. I let it cool and took out a few spark plugs, 4 of them looked a little golden brown and the others look good, just metallic with no carbon build up and no excess smell of gas. I let the car sit overnight and this morning it ran the same, perfect for the first 40 minutes, then rougher a rougher until it was just bogging out.
Let me also disclose that I am by no means even a backyard mechanic. I am trying to learn as I go and trying to try a few things before I can get the car to a real mechanic.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: My car doesn't want to run when its hot [Re: fireeng] #1481170
08/07/13 08:40 PM
08/07/13 08:40 PM
Could you pull up the original thread so we can see what's been done so far?
Re: My car doesn't want to run when its hot [Re: RapidRobert] #1481171
08/07/13 08:47 PM
08/07/13 08:47 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Robert, If you remember we were focused on vapor lock, but I'm thinking that's not it because the car will start back up after it stalls.
https://board.moparts.org/ubbthreads/show...e=5#Post7785169
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481172
08/07/13 08:51 PM
08/07/13 08:51 PM
Thank you. I remembered some of it. Deals like this I wish I could be there in person
Re: My car doesn't want to run when its hot [Re: RapidRobert] #1481173
08/07/13 09:35 PM
08/07/13 09:35 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I know, the list of "could be's" at this point is a long one.
I talked to my mechanic that works on my daily drivers and our mechanic at work and one of them is going to give it a look at next week when I get back from vacation.
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481174
08/08/13 09:06 AM
08/08/13 09:06 AM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Could be your pickup coil in the distributer going bad. They can act up when they get warm, but usually they just shut down when they get hot. Also could be coil. Still sounds like a vapor lock issue though. Maybe you could run with your hood off and see if the problem goes away.
If you have a good cooling system I would install a 165 degree thermostat. Might keep you cool enough to eliminate whatever problem you have.
Re: My car doesn't want to run when its hot [Re: rapom] #1481175
08/08/13 10:05 AM
08/08/13 10:05 AM
P
Paul_Fancsali Offline
P
The fuel is a problem now if you are in reform gas area. Myself I would change coil first and then pickup plate in dist. If you have a spare control box that would help. I had a 73 Cuda 340 that did the same thing it was the control box.
Re: My car doesn't want to run when its hot [Re: fireeng] #1481176
08/08/13 01:31 PM
08/08/13 01:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Scott,
I'm just going to throw this out there, because I had a similar problems years ago when I changed out the gas cap on my Challenger, I but a non vented cap on it, unknowingly, and the car would start to run ragged after 20-30 minutes, let it sit and what I thought was cooling off, it would restart and run fine for another 20-30 minutes...well it turned out I was starving the pump for fuel because of a vacumm/suction lock in the tank, I getting some fuel but not enough...could this be your issue?, perhaps a cap, or flip cap added during your resto?, or perhaps a vent/emission line not open, deleted, plugged, plumbed wrong during the resto?...if this might be the case, try running the car with no gas cap to see if the condition prevails,...sometimes it's the simplest things, or things we do to ourselves
Mike
Re: My car doesn't want to run when its hot [Re: DAYCLONA] #1481177
08/08/13 03:58 PM
08/08/13 03:58 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Scott,
Mike
Thanks Mike, I will try this first as there is no expense or waiting involved. I also ordered a new control box as I don't think it will hurt to have a spare on hand if that's not the problem.
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481178
08/21/13 04:44 PM
08/21/13 04:44 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
I tried running the car with no gas cap. It still did the same thing. It ran fine for 35 minutes then wants to stall out.
I changed the control box to a chrome unit and I am hoping to run it for an hour tonight.
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481179
08/21/13 04:57 PM
08/21/13 04:57 PM
Worcester, Mass
68goldfish Offline
68goldfish  Offline
Worcester, Mass
Had the same problem. Ran fine for about 30 min, and would die. I had a rotted filter in the tank. It would plug up and starve fuel. Later the tank debris would fall off the filter and it would run fine another 30 min. Check your fuel tank! Good luck!
Re: My car doesn't want to run when its hot [Re: 68goldfish] #1481180
08/21/13 08:21 PM
08/21/13 08:21 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Brand new fuel tank in the restoration. Just 600 miles on the car. Thanks for the idea though.
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481181
08/21/13 08:45 PM
08/21/13 08:45 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
How hot is the motor when it starts acting up?
And are the heat riser passages open or blocked?
Re: My car doesn't want to run when its hot [Re: Challenger 1] #1481182
08/21/13 09:08 PM
08/21/13 09:08 PM
IN
ahy Offline
ahy  Offline
IN
Can you put a "T" on the carb fuel line and rig up a fuel pressure gauge? Tie strapped to the cowl outside the passenger compartment works. Hook it up and run and watch. If it is vapor lock, debris in the tank or basically any fuel delivery problem you will see it drop before it stalls. Ideal is probably 5-7 psi and it should still run ok in the 3-4 range, at least at moderate load.
I'll add you have probably been all over the fuel lines but an older line can get soft from alcohol and get sucked shut by the pump. It will run for a while and quit. When it stalls, the suction is relieved and it may open up enough to run a little more. I had that problem on a PU.
Re: My car doesn't want to run when its hot [Re: Challenger 1] #1481183
08/22/13 08:46 AM
08/22/13 08:46 AM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Not exactly sure on the operating temp when it starts to act up. It shows normal on the dash gauge. Heat riser is removed.
Didn't get a chance to run her yesterday and it looks like rain today but hopefully I can sneak a ride in before it gets wet out.
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481184
08/22/13 09:14 AM
08/22/13 09:14 AM
Cincinnati, Ohio
Cincinnati, Ohio
Is the pickup and strainer new? I'd do what was suggested and hook up a tempory fuel pressure gauge and see if it's vapor locking.
Bragging...I drove my 340 in Vegas a couple weeks ago and it was 100+ degrees.
Re: My car doesn't want to run when its hot [Re: Challenger 1] #1481185
08/23/13 03:26 PM
08/23/13 03:26 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Got to run the car today with the chrome box. No change, car ran fine for 45 minutes then it will stall if it stays at idle for any extended period. My driveway is a bit of a hill and in order to back it in today after the 45 minutes I had to hold the gas and the brake in order to keep it from stalling out. Coil next I guess??? Not really sure how to put in the fuel line pressure gauge on my own.
Here is what the temp gauge said when it started acting up.
1971 Challenger
2013 Jeep Wrangler
Re: My car doesn't want to run when its hot [Re: fireeng] #1481186
08/23/13 04:30 PM
08/23/13 04:30 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Do you have a points distributor ? A timing light ? when it starts acting up like that have someone in the car keep it running and look at the timing light , if it's missing then you will see it , could be the coil , could be the pickup in the distributor or ...
But I would think if it was heat affecting ignition components wouldn't it make the car miss and fart at ANY RPM and not just idle ?
Re: My car doesn't want to run when its hot [Re: JohnRR] #1481187
08/23/13 05:18 PM
08/23/13 05:18 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
You mentioned it starts to act up at idle, what's happens if you put it to the wood?
Re: My car doesn't want to run when its hot [Re: WO23Coronet] #1481188
08/23/13 05:47 PM
08/23/13 05:47 PM
near New Haven, CT
fireeng Offline OP
fireeng  Offline OP
near New Haven, CT
Its seems to be able to drive if I give it some fuel but I do seem to think there is a bog or sputter present when it starts to run crappy. Those issues don't seem to be there when it first starts up and is running good.
I have a mopar electronic ignition conversion on it with the chrome box now. It still has the same coil that was on it with the points distributor. (I think that is my old 318 coil but I'm not 100% sure)
1971 Challenger
2013 Jeep Wrangler
