Re: hard start/death flash?
[Re: mod5v]
#1481069
08/08/13 02:29 AM
08/08/13 02:29 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Have you checked the keg intake from any signs of oil on the inside of the plenum.
My 92 Dakota had a similar issue when I first bought it. I changed the plenum gasket and she ran nice and smooth. No hard start. And milage went from 12mpg to 17mpg.
Have you used the key to check for codes?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: dodgeboy11]
#1481075
09/04/13 09:19 PM
09/04/13 09:19 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
Sounds like a fuel pump. Won't hold pressure on shut down, have to crank awhile for pressure to reach the rails and then it starts when it isn't at full pressure, runs rough till the pressure comes to full and then smooths out. Not saying that's what it is, but I've seen it before.
....Fuel pump plus the fact that the injector rail could be full of crap. Take the rail off and clean it out real good...if that don't work, then it's time to change the fuel pum p.
[Re: superwrench]
#1481076
09/04/13 10:28 PM
09/04/13 10:28 PM
Posts: 905 SD
zrxkawboy
SD
Put a fuel pressure gauge on it and see if the pressure bleeds off after you shut it down.
It's Swifty! Swifty, you toad sucker!
[Re: mod5v]
#1481077
09/07/13 12:19 AM
09/07/13 12:19 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
Easy fix, take out the IAC (idle air control) and clean it with brake cleaner and compressed air.
Common problem in all Mopars of that era.
Mo' Farts
Moderated by "tbagger".
