Negative Camber 70 Cuda
#1481064
08/07/13 03:32 PM
08/07/13 03:32 PM
Posts: 104 Arkansas
Nimbus426
Arkansas
My 70 Barracuda has hotchkis sport suspension installed with the aftermarket upper control arms. If I jack up the car and set it back down the wheels are straight up and down. But when I drive it a bit they splay back out. So I'm guessing something is loose. I tried taking the upper control arm off and putting it back on and tightening it down good to see if it would make any difference but no dice. I'm not very experienced with suspension. Any idea what would cause this? Thanks
-ERIC
Re: Negative Camber 70 Cuda
[Re: autoxcuda]
#1481066
08/07/13 05:13 PM
08/07/13 05:13 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I would not think a person not well versed in suspension in his own words would notice a street performance setting of negative camber, unless something was wrong. The reasons however for the difference under the OP's situation has been explained IMO.
[Re: Nimbus426]
#1481067
08/07/13 06:03 PM
08/07/13 06:03 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Start with the obvious, jack the car up, wiggle/pry the tires and components around looking for obvious tell tale signs somethings loose, or excessive play,...it might be something as simple as no preload on the wheel bearings...
