Re: sprag failure
[Re: Plymouth340]
#1480703
08/06/13 10:07 PM
08/06/13 10:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok.. you got me.. whats a starting line enhancer ... I thought that was a 150 shot.... I think you might have broke it on the previous run... you start in 2nd in the burn out box so its not applied
Re: sprag failure
[Re: MR_P_BODY]
#1480705
08/06/13 10:36 PM
08/06/13 10:36 PM
Posts: 501 CEDAR RAPIDS
Plymouth340
CEDAR RAPIDS
starting line enhancer.....since you can have your gas pedal to the floor, and have the Starting Line Enhancer hold the motor at a low preset RPM until after your top bulb goes out, at that point the motor goes up to the 2-step
Re: sprag failure
[Re: Plymouth340]
#1480707
08/06/13 10:38 PM
08/06/13 10:38 PM
MR_P_BODY
long story...google it. the dye hard box racers know what they are..broke it on the previous run? but why?
The easiest way is to pedal it while still in manual low gear... if you decell it then hit it again... did you spin in the previous run
Re: sprag failure
[Re: MR_P_BODY]
#1480709
08/06/13 10:42 PM
08/06/13 10:42 PM
Plymouth340
CEDAR RAPIDS
did not spin
Re: sprag failure
[Re: Quicktree]
#1480711
08/06/13 10:46 PM
08/06/13 10:46 PM
Plymouth340
CEDAR RAPIDS
did you roll out of the burn out in 1st gear?
no ...2nd then out of the box in 3rd like always
Re: sprag failure
[Re: MR_P_BODY]
#1480714
08/06/13 11:04 PM
08/06/13 11:04 PM
Plymouth340
CEDAR RAPIDS
By chance did you back up a little then pull forward.. if you dont pull forward about 4' it wont set the sprag
didn't backup..poped it in netrual after burnout then pulled ahead but don't remember how far but someone else told me to pull ahead about 5 feet after putting it back in gear so will remember that..thanks
Re: sprag failure
[Re: THE GLASS MAN]
#1480716
08/07/13 12:14 AM
08/07/13 12:14 AM
Posts: 4,075 Mo.
racerx
Mo.
Check the length of your driveshaft.
so what cha think that the driveshaft may be too long and stressing the sprag?
Re: sprag failure
[Re: THE GLASS MAN]
#1480717
08/07/13 06:25 PM
08/07/13 06:25 PM
Plymouth340
CEDAR RAPIDS
the driveshaft length hasn't changes in 18 years so I don't think that's it..
Re: sprag failure
[Re: racerx]
#1480719
08/08/13 02:43 AM
08/08/13 02:43 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
Motor might be moving to the rear a tad when that trans brake button is released. Do you have a strut rod on the motor to keep it from moving to the rear. Have you changed over to s/s springs lately. When you unbolt the rear u joint, how much does your drive shaft slip into the tranny ?
