Bearing Retainer Problem #148045
11/10/08 12:02 AM
11/10/08 12:02 AM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
The snout of the bearing retainer on my 4 speed broke off clean at the base, I noticed it when I was trying to push the clutch fork back to the rear to install the clutch linkage, When I pushed rearward on the fork I can see the TO bearing move forward contacting the forks on the pressure plate. The piece that broke off moves with the TO bearing. The only thing we did was rotate the crank to tighten the pressure plate bolts. Now, I need to pull the tranny and see what's up. Any suggestions?
Re: Bearing Retainer Problem [Re: dart4forte] #148046
11/10/08 12:35 AM
11/10/08 12:35 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
turn the heat on a half hour before you start taking in out... oh yea,,, you need to jack the car up too...
I am truckless..
Re: Bearing Retainer Problem [Re: 340SHORTY] #148047
11/10/08 01:26 AM
11/10/08 01:26 AM
Mesa, Arizona
Mesa, Arizona
It's up on the rack and I have a tranny jack as well
Re: Bearing Retainer Problem [Re: dart4forte] #148048
11/10/08 10:54 AM
11/10/08 10:54 AM
scratchnfotraction Offline
yep,I had one that broke once too
my shifter would shake and have a bad vib 2-3 gear
unreal noise and vibs,I think it was from the "tube" in the t-o bearing riding on the input shaft and wanting to spin in the t-o bearing
stoped when I replaced the bearing retainer
mine snaped at the base also and was just in the t-o bearing
good luck
Re: Bearing Retainer Problem [Re: scratchnfotraction] #148049
11/11/08 01:58 AM
11/11/08 01:58 AM
Mesa, Arizona
Mesa, Arizona
Contacted Brewers, ordered a billet steel retainer
