E-body Armrest Bracket #1479732
08/04/13 10:19 PM
08/04/13 10:19 PM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
Does anyone have a picture of the backside of a 1970 E-body door panel showing how
the armrest cup and support bracket attach to the door panel? Any tips on putting them together. Been working on it all day, don't think my repop panel is very good.
Steve
68 Coronet R/T Hemi
70 Challenger 440-6
70 Challenger R/T S/E 440-6
71 Challenger Convert.
70 Superbird 440-6
Re: E-body Armrest Bracket [Re: Knappy] #1479733
08/04/13 10:45 PM
08/04/13 10:45 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I just did this but I looked on my phone and I did not take pictures.I guess that is the advantage of having lots of spare e-body parts to go back and look at.You say you are having problems with the fit of your door panels? If you have the Palco's or accuform, then they fit like socks on rooster. I bought the new ones from Metro and they fit great. I got the B,E,& A pads and they fit fine in the opening. I can get you a picture tomorrow from a spare panel at the shop.I can't really describe how it should look without a picture in front of me, I have slept since then. The new pads have a metal core and the holes may not line up right. I had to drill a starter hole in mine to get it threaded.
Re: E-body Armrest Bracket [Re: fastmark] #1479734
08/04/13 11:11 PM
08/04/13 11:11 PM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
I am having a hard time installing the armrest cup and trying to figure how the support bracket attaches. The panels install ok but the armrest cup, handle and brace do not want to line up. I think the padded inside handle is the problem. A picture would be great.
Steve
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
Re: E-body Armrest Bracket [Re: Knappy] #1479735
08/05/13 11:24 AM
08/05/13 11:24 AM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
its been a while but it should all fall into place..the armrest, cup and that bracket can pretty much go only one way..you might have to flip it upside down or so but most likely it lines up...is it all new stuff? repro things are not always drilled right.. i have the repro inside door handles and door locks and they do not fit out of the box..i was better off with the old stuff
Re: E-body Armrest Bracket [Re: Knappy] #1479736
08/05/13 12:33 PM
08/05/13 12:33 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I just put Metro door panels on last spring. The bracket only holds the armrest on. The cups float until the big Philips head screws mount the bracket and the cups to the door itself. I had no fitment issues with the door panels except they needed a little convincing to get them over the door edges.
Craig
Re: E-body Armrest Bracket [Re: denfireguy] #1479737
08/05/13 12:39 PM
08/05/13 12:39 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
If you don't get a picture before I get home, I should be able. I'm in the final stages of the resto. on my friend's '71 Challenger and have the door panels off right now....... So, I can take a picture of the back side...
Troy
Houston Mopar Connection Club
Re: E-body Armrest Bracket [Re: Knappy] #1479738
08/05/13 02:47 PM
08/05/13 02:47 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
Not sure if this what your looking for but this is the setup on my 1971 R/T Challenger, all original parts.
Re: E-body Armrest Bracket [Re: KillerBee] #1479739
08/05/13 05:37 PM
08/05/13 05:37 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I have alot of these type of pictures, I just tried posting them but they are too large to post from my mobile. If you PM me your email, I can help you out.
Edit: I found your email in your profile and sent them.
Re: E-body Armrest Bracket [Re: Suregrip391] #1479740
08/05/13 11:19 PM
08/05/13 11:19 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
This is my 70 cuda pass side brace,cup and armrest out of the panel.The new one will not line up like this until you drill the holes in the armrest where the smaller screws go. Drill them and then slip in the armrest in the new panel. Install like shown in the photo and you are go to go.
Re: E-body Armrest Bracket [Re: fastmark] #1479741
08/06/13 12:40 AM
08/06/13 12:40 AM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
These pictures are great. Looks like only one screw holds the support bracket to the handle. My door handle is too small to fit around the cup. I am going to get new ones from Legendary and see haw that works
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
Re: E-body Armrest Bracket [Re: Knappy] #1479742
08/06/13 10:43 AM
08/06/13 10:43 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Well, there is one on each end plus the 2 screws with a flat washer that hold the pad to the door panel. That a total of four. The two big holes are the one where the big long screw goes to the j nut in the door itself.
Re: E-body Armrest Bracket [Re: fastmark] #1479743
08/07/13 11:52 AM
08/07/13 11:52 AM
Texas
K
Knappy Offline OP
Knappy  Offline OP
K
Texas
OK, Who sell white armrest pads for 71 Challengers?
68 Coronet R/T Hemi
70 Challenger 440-6
70 Superbird 440-6
