This listing is for a GTS Hood, part# 300-2067, which is designed to fit the 1967-1969 Dodge Dart. Auto Metal Direct (AMD) hoods are designed to be a direct bolt-on replacement to your vehicles stock hood. All applications utilize your vehicles stock hinge and latch assemblies. Each hood features a fully finished, factory style, underside. Unlike fiberglass hoods, AMD
steel hoods will not flex or warp over time. Regardless of where you are located, AMD
steel hoods will stay looking great for years to come! This hood arrives in a black EDP coat finish. This is not a primer. This is a sealer put on the hood to protect against rust. All AMD hoods require normal prep work (test fit, sand, prime) before paint can be applied. We strongly recommend having a qualified auto body shop paint and install this hood.
