ManualTransmission swap #147949
11/09/08 10:26 PM
11/09/08 10:26 PM
Kennewick, Wa.
71vert340 Offline OP
Kennewick, Wa.
I thought I'd run this by the people on the board. I'm selling an 833OD tranny from a 76 slant6 Volare to someone who wants to put it in his /6 1967 Dart. I'm including with it the bellhousing, shift rods, shifter, and driveshaft (for the different yoke size). His Dart has the manual 3 speed tranny in it now. I'm assuming his Dart has the short tailshaft tranny. I want to make sure this will work for him so he has a usable setup. Anything I'm forgetting. Thanks.
Re: ManualTransmission swap [Re: 71vert340] #147950
11/10/08 12:03 AM
11/10/08 12:03 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Clutch safety start switch, maybe?
I think the reverse shifter rod for F- and M-bodies use is different from any other body, so that may not work for his/her '67.
Re: ManualTransmission swap [Re: In_The_Pink] #147951
11/10/08 01:10 AM
11/10/08 01:10 AM
Kennewick, Wa.
Kennewick, Wa.
It could be the reverse rod on the manual 3 speed tranny currently in the car would work on the OD tranny. I'm just trying to be sure it's a do-able swap so he won't feel I sold him a setup that wouldn't work. Thanks
Re: ManualTransmission swap [Re: 71vert340] #147952
11/10/08 02:18 AM
11/10/08 02:18 AM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
No, with a 3-speed manual trans, the reverse and 1st rod is shared, as is the 2/3 rod.
It's definitely do-able. There's someone over at slantsix.org adding the same trans to an early A-body- check out the Trans & Rearend section.
Re: ManualTransmission swap [Re: 71vert340] #147953
11/10/08 03:22 AM
11/10/08 03:22 AM
USA
rftroy Offline
rftroy  Offline
USA
The shift fork is also different. OD4 only.
The pivot point for the fork is farther away from the crank/transmission centerline due to the large diameter 5-1/8" transmission pilot.
Bob
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: ManualTransmission swap [Re: rftroy] #147954
11/10/08 09:06 AM
11/10/08 09:06 AM
Kennewick, Wa.
Kennewick, Wa.
I'm also giving him the z-bar for the setup which might help on the fork alignment. I'll have to see if I have the original fork. Thanks.
